Old 11-05-2021, 05:37 PM   #1
Asshat
Asshat's Avatar
Lower hood valance replacement
Has anyone done this? Looking to replace my rusted out lower valance with one from The Truck Shop.
Wondering how difficult it is to cut it out and weld back in place.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 11-05-2021, 08:23 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Lower hood valance replacement
I haven't done one yet, but starting with post Number 663 will probably help show how it comes apart and goes back together
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 11-06-2021, 12:21 AM   #3
TxCajun
TxCajun's Avatar
I did this on my truck. Not too hard a task, and the results were good.
See details in post #72 to #74 in my build.
Wampus Cat Build: http://67-72chevytrucks.com/vboard/s...d.php?t=759550
TxCajun is offline   Reply With Quote
Old 11-06-2021, 07:20 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
http://67-72chevytrucks.com/vboard/s...=759550&page=3
Old 11-06-2021, 10:13 PM   #5
PGSigns
PGSigns's Avatar
Get the inner panel when you do it. Its usually as bad as the outside panel.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-08-2021, 04:30 PM   #6
racecougar
racecougar's Avatar
Been there, done that. It isn't difficult at all, just time consuming.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 11-08-2021, 08:51 PM   #7
karlbenz
wish they made that for GMC
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
1990 Chevy Bus 8.2l fuel pincher 8800 miles
1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO
karlbenz is offline   Reply With Quote
Old 11-25-2025, 12:37 AM   #8
66_c10
Has anyone had to cut the aftermarket valance it to make it work? I bought mine from LMC and it fits good on one side but comes up short on the other and vice versa. What do people normally do to make it fit properly?
66_c10 is offline   Reply With Quote
Old 11-25-2025, 09:01 AM   #9
joesscamaro
If I'm looking at the area you're talking about, I would just add a little metal to the original piece to cover that little gap. Looks like that may be the easiest fix.
joesscamaro is offline   Reply With Quote
Old 11-25-2025, 12:56 PM   #10
TxCajun
TxCajun's Avatar
We had a similar problem, with one end being slightly short and leaving a gap.
We used pliers to straighten out the flanges on that end of the new part, and then re-bent them to make the end longer and close the gap. Then, massaged the area with a hammer and dolly to clean it up.
I don't have any pictures showing this modification in detail, but the solution worked well.
