Old 11-05-2021, 11:26 PM   #1
Peanut74
Heater Control Disassembly How To
Thought I would document how I took my heater control apart to repair the lever arms. I have two A/C control assemblies and both have the middle lever arm broken. So now that I have it apart just need to get the lever arms ordered so I can replace the arms and get it in the truck.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 11-05-2021, 11:36 PM   #2
Peanut74
Re: Heater Control Disassembly How To
How to remove the cable retainer clips courtesy of LockDoc
http://67-72chevytrucks.com/vboard/s...d.php?t=211815
Old 11-05-2021, 11:37 PM   #3
jimijam00
A write up with pics?
Totally awesome.
jimijam00 is offline   Reply With Quote
Old 11-08-2021, 06:28 PM   #4
Peanut74
Yes indeed. Did the write up to make sure I knew how to put it all back together again once my new control arms come in.
Old 11-08-2021, 08:52 PM   #5
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Subscribed and thank you..
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 11-10-2021, 11:16 AM   #6
NorCalC20LWB
Very nice write up, wish I would have seen this a couple years ago when I did mine. Quick question, when I bent the face plate tabs up I think two broke. Any trick to to bending that pot metal, or whatever it is, so they don't break when bending/tapping them down during reassembly?
NorCalC20LWB is offline   Reply With Quote
Old 11-12-2021, 01:13 AM   #7
Peanut74
NorCal, I did break one tab out of the six. I used a pair of pliers the width of the tab to bend them out of the way. I bent them just enough so that the faceplate cleared the tabs. The real test will be when I try and put it back together.
Old 12-03-2021, 10:08 PM   #8
Peanut74
Well I got my new control levers and thought I would do a write up on it. I did break two of the six tabs. Hope it is helpful and makes sense.
Old 12-03-2021, 10:10 PM   #9
Peanut74
One last slide
