Old 11-06-2021, 01:59 PM   #1
Asshat
Asshat's Avatar
Conversion tank
Want to confirm the connections on the tank, the smallest is for the canister, correct?
Also, looking for options for a filler port.
And, I’ll need to remove some of the bed rails too?
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 11-06-2021, 03:45 PM   #2
Asshat
Asshat's Avatar
Re: Conversion tank
Looks like I need to cut this rail that bolts to the bed boards.
It’s the only way to make it fit.
292, 4-speed
Old 11-06-2021, 08:11 PM   #3
Asshat
Asshat's Avatar
Re: Conversion tank
Wondering how these straps are supposed to mount. Are these intended to be bent into the correct shape for tha application?
Someone must have already installed this style tank. I didn’t find any pics. Mostly seeing pics of the camaro tank install.
292, 4-speed
Old 11-06-2021, 10:04 PM   #4
AcampoDave
AcampoDave's Avatar
Re: Conversion tank
I bent my straps to fit and in the area where the bolt goes thru them to the crossmember, I doubled the end back over itself and creased it down real flat in the vise so as to have some extra meat for the bolt to pass thru. They were perfectly flat though in my kit, where yours appear ro have been pre formed
AcampoDave is offline   Reply With Quote
Old 11-07-2021, 06:33 AM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Conversion tank
A good video on the install - https://youtu.be/orfmf9YlFak
Old 11-07-2021, 07:55 AM   #6
Asshat
Asshat's Avatar
Re: Conversion tank
That helps a lot - Thank you!
292, 4-speed
