Old 11-06-2021, 09:50 PM   #1
hgs_notes
GEARHEAD
hgs_notes's Avatar
Cab Roof Replacement
I'm helping a friend out with rust repair on his cab. Started out with the usual problem areas. Rockers, lower kick panels, bottom of the kick panel vents from leaves and rodent nests, small floor patches, etc. The cab had a spot light through the middle of the roof. The cab had been sitting outside for several years and it leaked. So the middle of the inner roof panel was rusted. Then we found pinholes above both doors. There was also damage to the drip rails and outer edge of the roof where the cab was lifted using a strap that rolled up the drip rail and dented the outer roof.
Neither of us have attempted a roof replacement before but he decided to spend another $500 on new roof panels and we gave it a shot. Removing the old panels wasn't that hard, just a lot of spot weld drilling.
When we got the outer skin removed, mouse nests fell out of both sides above the doors. Most of the damage to this cab was caused by sitting outside. Nice and moisture. This was a nice rust free cab before that.
hgs_notes is offline   Reply With Quote
Old 11-06-2021, 10:23 PM   #2
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Cab Roof Replacement
I'm using 3M panel adhesive to secure the new parts. The cab is mounted on a dolly. The frame around the doors and windshield are pretty stout so we didn't feel the need to add more support. We ground down all of the spot weld areas and cleaned up the surface rust, especially on the areas where the adhesive will go. We pre-fit the inner roof panel first and it looked like a really good fit.
This is where we made a mistake but didn't realize it until later.
Having no experience doing this and finding nothing online or on the forum we figured that the inner panel had to go in first because it's the only way to get it in over the top of the A pillars and the rear inner cab panel. Then put the outer skin on. Attaching the inner roof panel was easy enough. We used a few self tapping screws in the rear pinch weld area and clamped the front and sides to the inner structure. Everything looked great.
But then getting the rear pinch weld together for the outer skin is difficult. I managed to get it together pretty well but it could have been better if we changed up our plan.
What we should have done is also remove the rear inner panel around the rear window. I believe that's how it was done at the factory. If you take that out, then you can put the outer roof skin on first and be able to clamp or weld that rear seam. Then you weld or glue the inner roof panel to the inner rear window panel together. Get that done then install those into the cab as a single piece.
But we didn't do that so getting the rear seam aligned and tight was a little more difficult. Learn from our mistake!
Old 11-06-2021, 10:30 PM   #3
Getter-Done
Getter-Done's Avatar
Thanks for sharing
I really like your signature
The early bird gets the worm,
84 Chevy K-20
Old 11-06-2021, 10:39 PM   #4
hgs_notes
GEARHEAD
hgs_notes's Avatar
Once the inner roof panel was set up we put the sound deadener in. We used fatmat. Then the outer skin could go on. The fit wasn't bad but needed a little more tweaking. This would have been easier if we had done it in the order described in the previous post. Oh well, live and learn, make the best of it.
I had to do it in 2 steps. First glued the rear seam. Then after that set up I glued and clamped the front and sides.
Old 11-06-2021, 10:50 PM   #5
hgs_notes
GEARHEAD
hgs_notes's Avatar
Last step was doing the drip rails. Probably the easiest part of the job. BTW, removing the old drip rails was probably the worst part of the job. They had spot welds about every inch! Lots of drilling.
The new ones fit up nice. Clean everything up, mix up the adhesive and clamp in place!
Using adhesive has a lot of benefits. It completely seals the joints and keeps moisture out so it won't rust after. It's very strong and if you use the right one you have plenty of time to move and adjust the pieces. It's how the manufacturers are building them now and how most body shops do things. If a seam splits you can still drill a small hole and plug weld. And in some areas I use adhesive and plug welds together.
Old 11-06-2021, 11:07 PM   #6
hgs_notes
GEARHEAD
hgs_notes's Avatar
This thread was just to share our experience doing an uncommon job that really wasn't that difficult to do. The new panels weren't cheap, I think $500 for the roof skins and another $50 or so for the drip rails. The adhesive is about $45-50 a pack and I used more than one pack for the roof replacement. You need a special tool to use the adhesive that cost about another $50-60. I bought mine several years ago when I did the restoration on my 71. Mine is for the SEM version of adhesive but also works with the 3M stuff. But the 3M tool won't work on the SEM adhesive. They have different diameter tubes.
As I said, we didn't have prior experience doing this and maybe we made mistakes. If any pros want to comment, criticize or just share pro tips that would help everyone. If you need to do this and you have any experience with rust repair, you can handle it.
Oh, you will need a TON of vise grips. The kind for this type of work. You can see what I used in the pics. And we used every single one we could get our hands on. I filled a 5 gallon pail with vise grips.
Old 11-06-2021, 11:33 PM   #7
57taskforce
All about them K’s
57taskforce's Avatar
Very nice work!
Tyler
57taskforce is offline   Reply With Quote
Old 11-07-2021, 05:14 AM   #8
72 tigger
72 tigger's Avatar
Good tips- thanks for sharing! Looks really good
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 11-07-2021, 09:11 AM   #9
BigBird05
Where did you find good drip rails? All of the comments say they such and most venders don't carry them.
BigBird05 is offline   Reply With Quote
Old 11-07-2021, 09:41 AM   #10
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Thanks for sharing the info HG.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 11-07-2021, 09:54 AM   #11
hgs_notes
GEARHEAD
hgs_notes's Avatar
Bowtie truck stop is local to me. Call Kevin gramentz at 507-723-2843. His prices are comparable to anyone's and he always tries to get the best version of the parts. Doesn't want to sell light weight, low quality, poor fitting parts. And he is pretty well stocked.
Old 11-07-2021, 10:52 AM   #12
hgs_notes
GEARHEAD
hgs_notes's Avatar
Originally Posted by A1971Blazer View Post
Inner roof patch
Attachment 2143869
Man that's a bunch of work. Looks good. We were thinking about cutting the top of a donor cab, and if the A pillars were also rusty that's probably what we would have done. But he didn't really have a good roof on any of his parts trucks.
Old 11-07-2021, 10:53 AM   #13
too much stuff
Roadtrip!
too much stuff's Avatar
Nice work.
I have a roof already cut off and ready to go if you need to do another one...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 11-07-2021, 11:03 AM   #14
68 C10 Driver
Outstanding work! And I thought I had a rusty cab...
You are indeed a gifted craftsman. I'll certainly be following this build. Thanks for sharing!
68 C10 Driver is online now   Reply With Quote
Old 11-07-2021, 12:16 PM   #15
Thundarr
Thundarr's Avatar
INCREDIBLE.
Subscribed and bookmarked if I ever get the courage to take this on for my GMC.
Thank you!
1971 GMC C15 Sierra Grande SWB
1972 Chevy C10 Custom Deluxe LWB
2018 GMC Yukon Denali
Thundarr is offline   Reply With Quote
Old 11-08-2021, 10:17 AM   #16
landarts
landarts
Nice work on the roof. Been there and done that it is a boat load of work and takes some time and patience to do it right.
Really like the approach and craftsmanship. Again nice work!
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 11-08-2021, 07:05 PM   #17
BigBird05
Thanks for the drip rail info.
Old 11-10-2021, 10:44 AM   #18
hgs_notes
GEARHEAD
hgs_notes's Avatar
Sure, NOW brothers puts out a video on doing a roof. Oh well, their tutorial isn't quite the same situation we had and they welded rather than using adhesive. I think they HAD to weld the rear seam because they didn't do the full inner roof panel so there isn't access to the inside with that in place, so the rear cab seam gets welded closed. We discussed it and decided to stick with the original look rather than weld it and smooth it out.
There was also a patch panel someone made a while back, not sure if it's still available, but it basically removed the rear seam and replaced it with a radiused piece for a smoother look.
https://www.youtube.com/watch?v=S_0ImjRL6jI
Old 11-10-2021, 12:27 PM   #19
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work! I have a cab I have to do a complete roof on as well. The inners down the b pillar are rotted too unfortunately so I will be cutting the pillars and doing it that way.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-10-2021, 08:47 PM   #20
Greasey Harley
Greasey Harley's Avatar
Originally Posted by hgs_notes View Post
I'm helping a friend out with rust repair on his cab. ....
Dang. I wish I had friends like you!! Well done
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 11-10-2021, 11:16 PM   #21
Roostre
Roostre's Avatar
I get most of my parts from bowtie truck stop. Kevin and Lisa are great people and have always done right by me. Whenever I go up there on a parts run, I plan on an extra 45 minutes of talking to them.
What are you planning on using for drip rail sealer? I used some stuff from 3M and have found it peeling out. I think it's because I was lazy and didn't remove the factory ecoat from the new roof panel and the sealer didn't stick to it. I need to clean out all of the sealer and grind away the ecoat.
Roostre is offline   Reply With Quote
Old 11-11-2021, 04:39 AM   #22
BCOWANWHEELS
I,d just have looked for a nicer cab personally
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-11-2021, 01:23 PM   #23
Dieselwrencher
That's easier said than done in our area. Usually the entire floor is roached or the roof and floor are roached. When you do find a good usable cab, you'll be spending $500 for a bare rusty cab. It's nuts.
Ryan
Old 11-11-2021, 01:28 PM   #24
A1971Blazer
A1971Blazer's Avatar
Mine is a 67 small window...even harder to find in good condition...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 11-11-2021, 02:33 PM   #25
Dieselwrencher
A member here in southern Iowa had one at a reasonable price. Needed rockers/inner rockers, light floor repairs and cab corners. Russ/counter had it.
Ryan
