70 C-30 dump bed parting out new parts added 11/8
Selling everything but the cab and engine. I would like to sell the rolling chassis as 1 piece and will have the 4 speed with pto in it. All prices negotiable, Shipping cost varies by parts and can only ship on saturdays
292 air cleaner assembly 75.00 (SOLD) Engine and headlight harness, temp sender connector missing 75.00 Complete rolling chassis 750.00 (SOLD) Front side marker lights 20.00 Grill parking lights 40.00 Let me know if you see something you want Last edited by 70CHEVYBB; 11-14-2021 at 05:40 PM. Reason: Addin more parts |
Re: 70 C-30 dump bed parting out
6cyl fan shroud. 25.00
Front and rear stainless window trim, 1 dent as seen in pic 150 for both. Shipping will be a little expensive (SOLD) Grille with no cracks but has 1 Bar missing in picture 75.00 Last edited by 70CHEVYBB; 11-10-2021 at 09:35 AM. |
Fan spacer and water pump pulley. 40.00
Door mirror brackets. 30.00 C-30 and 292 fender emblems all studs intact 40.00 |
BlahBlahBlah
I would love to have had that dump bed. Always too far away.
![]() Join Date: Sep 2019
Hi! How much for the front parking lights + the parking light and headlight wiring harness?
Thank you! |
Bench seat tracks. 100 shipped
Dash Bezel with no gauges with cab harness this is a 4 speed truck 75.00 Booster and bracket 60 Radio delete plate and matching ash try with lighter plug 75.00 (SOLD to jimer1964) Reflectors in metal box. 30 Last edited by 70CHEVYBB; 11-09-2021 at 09:56 PM. |
I would be interested in the window trim if shipping isn't prohibitive. 46947 is the zip. Let me know. Thank you.
I would be interested in the PS pump with pulley and brackets, also the fan pulley. Could you give me a couple of better pictures, Thanks
![]() Join Date: Jan 2007
I will take the ash tray and delete plate is glove box door available? interested in that also
Listing is confusing I am still in on the radio delete and ash tray but you have it listed 2 times? One is with dash bezel and light Harness.i guess you are just mentioning the delete and ash tray? Just curious I am also interested the glove box lid if available just wanting some clarification ok Thank you
#13 | |
I was trying to clarify the cab harness as having no radio and no lighter with cab lights.(I see where its confusing) I would guess the harnesses are different with a radio and lighter. I sent you a pm |
#14 |
#15 |
Can you send me some pictures of the bracket and assembly. I would still like the pump also, I can rebuild it, also need the water pump 2 grove pulley.
#16 |
![]() Join Date: Sep 2007
id be interested in the carb abd linkage off that 292 if we can work a deal, also the air cleaner assy
1967custom Last edited by michael bustamante; 11-09-2021 at 06:53 PM. |
#17 |
![]() Join Date: Jul 2008
Interested in the E brake parts from the end of thre cable that comes out of the cab to the rear brake cables and the rods that go to the frame
1965 c/10 swb 1969 c/10 lwb
#18 |
![]() Join Date: Aug 2014
I do not know where I stand in this line, but I will take the whole air cleaner assembly. I did not know if Michael wanted the whole assembly or just part of it. Let me know. -George
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
#19 |
The last photo in post #7 shows what looks like it might be a part of the transmission inspection cover. Just a long shot but wondering what sort of transmission was in the truck? Looking for a part that went with the SM420 4 -speed. I have the lower inspection cover. I just need the top flat piece. Most likely though this is not from an SM420 but I thought I would ask.
#20 |
#21 |
I pulled the bracket and has two broken ears. Let me know what you want to do?
#22 | |
#23 | |
110 shipped Air cleaner and linkage Last edited by 70CHEVYBB; 11-09-2021 at 10:06 PM. |
#24 |
Steering column brackets and pedal stop plates?
#25 |
| Bookmarks |
