Old 12-27-2003, 06:21 PM   #1
tomfg
64 1/2 ton Pulling Rear Axel
Would someone tell me how to pull the rear axels on a 64 Chevy 1/2 ton? I pulled the cover on the rear end, but don't see any c-clips or the likes. Don't believe I see a retainer on the brake backing plate.....do I? Thanks for any help, Tom
tomfg is offline   Reply With Quote
Old 12-27-2003, 11:00 PM   #2
zenish
there should be a large shaft maybe 3/4" in diameter and around four inches long in the middle.its held in place with a small bolt.remove the bolt.slide the shaft out.then push the axle in and you will see the clip.remove the clip and the axle will pull out.
zenish is offline   Reply With Quote
Old 12-28-2003, 12:23 AM   #3
tomfg
Many Thanks Zenish, will look it over again in the a.m.
Old 01-01-2004, 10:42 PM   #4
Shorty Cox
Zenish is correct.
Shorty Cox is offline   Reply With Quote
Old 01-02-2004, 08:46 AM   #5
tomfg
Zenish was correct
Zenish was correct on the axel removal. Axels are out, new seals going in today. Thanks.
