11-10-2021, 03:25 PM | #1 |
Which model fans??
I've been hunting for a close to original metal fan. The only advice I got was the derale 17119, metal 19" I believe, but as usual it's hard to find, classic industries has one, but I'll have to wait longer for shipping. My clutch for fan has arrived from Hayden, model 2747. The derale 17119 will fit clutch. Are there any other fan models that will fit possibly easier to find??
85 GMC Sierra. Small block. I found 2 shrouds, one is $20....the other is $60. The one cheaper was saying for big blocks only, and more expensive one fits both.
: Eli540 86 gmc 2500 longbed Carb 5.7, rwd, 400 tranny. Last edited by ellisjay2; 11-10-2021 at 03:54 PM. |
11-19-2021, 01:03 PM | #2 |
Re: Which model fans??
Cheap generic advertising. They use the same image for different items. It's up to you to read the details & order the part you think is the best option. Some put the disclaimer 'image may not be of the actual part'; sometimes they don't.
11-19-2021, 05:28 PM | #3 |
I just went with lmc trucking..they have more original parts to fit....fan model I'm going with derale 17118 since it will fit Hayden clutch 2747.. it's just a 6 blade instead of 7
: Eli540 86 gmc 2500 longbed Carb 5.7, rwd, 400 tranny. |
11-19-2021, 06:35 PM | #4 | |
I ordered a radiator shroud & core support top-plate for my '89 Squarebody dually w/a factory 7.4l BBC. I ordered the set-up for a BBC. What I received was nothing like what was on my truck (factory stuff).
