Old 11-10-2021, 10:51 PM   #1
Mike80D
Mike80D's Avatar
Factory correct plug wires
Hello, does anyone happen to know the part # for the factory correct plug wires for a 72 350 engine, or a good source? I feel like the ol gal needs a set. Thanks in advance.
Mike80D is offline   Reply With Quote
Old 11-10-2021, 11:52 PM   #2
allchevy58
allchevy58's Avatar
Re: Factory correct plug wires
Rockauto shows ACDELCO 9508N or 508N for 72' C10 350. I used ACDELCO 9508N on my 72' K2500 GMC with a 350, fit perfect.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 11-11-2021, 12:38 AM   #3
Accelo
Accelo's Avatar
When you change your wires consider posting the length and plug number they came from. For me it has been difficult to get the lengths in the correct position.
As difficult as it is to get them under the motor mount I would appreciated only doing it once.
Accelo is offline   Reply With Quote
Old 11-11-2021, 06:08 AM   #4
Mike80D
Mike80D's Avatar
Thanks for the info. I didn’t think to check there.
Old 11-11-2021, 06:10 AM   #5
Mike80D
Mike80D's Avatar
Thanks for the tip. Getting them routed through the mount is my biggest fear, and reason I haven’t tackled the job yet.
Old 11-11-2021, 06:22 AM   #6
Mike80D
Mike80D's Avatar
Looks like the 508N are what I will get. Might have to find a NOS set as I am wanting the correct Delco, and Packard suppression markings on the wires. Guess I’m picky haha!
Old 11-11-2021, 09:12 AM   #7
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
When I did my restored my jimmy the set I got were long enough to go through the motor mounts. Now my motor is out should be able to get a free set. Have to check and see where I got them.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 11-11-2021, 03:14 PM   #8
BigBird05
For the correct # spark plug wires check with ecklers.
BigBird05 is offline   Reply With Quote
Old 11-11-2021, 03:27 PM   #9
FirstOwner69
FirstOwner69's Avatar
These reproduction wires may be something to consider. They are dated 1-Q-72. They also have 3-Q-71. Both would be appropriate for a '72 truck depending on truck manufacture date. I don't have personal experience with them, but Lectric Limited has a pretty good reputation.
https://www.lectriclimited.com/catal.../category/747/
Jim
FirstOwner69 is offline   Reply With Quote
Old 11-11-2021, 11:07 PM   #10
71 super
71 super's Avatar
The repopulate date coded wires are the pieces you are looking for. They are a little pricey compared to generic replacements but I have them on 4 trucks and are always perfect fit and correct markings
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 11-12-2021, 09:08 AM   #11
67C10Step
67C10Step's Avatar
When you pull the ones back through the motor mount tie some sort of string or something on them and then tie that to the new wire. Will help you snake it back through a bit easier.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
