Old 12-27-2003, 07:26 PM   #1
BowTieMan
BowTieMan's Avatar
Pre runner
I was thing about a pre runner. What do you guys use for suspension? I want a 73-80 chevy short bed. I only want to go 2-3 in higher. Would a 2 in body lift be a bad idea? If I did the body lift could I run 32x11.50? If so would a 16X10 rim or would a 16X8 rim be better?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 12-28-2003, 12:26 AM   #2
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Is this truck a 2 or 4 wheel drive?!
Suspension for sure over having a body lift. Get the WHOLE truck higher, not just the body. Remember you will have stuff hanging down that will catch on rocks/dirt/???.
If you don't already own the truck, I would suggest a longer wheelbase truck, such as a longbed. Simply because it is longer. Ever drive a Jeep, then drive a longwheelbase truck; the Jeep seems a little squirly... IMO anyway. In highschool, 4wheeling was the thing, whether you were crawling the rocks or doing 100+ in the boonies on old service roads. I learned that a little longer truck was way easier to handle at higher speeds.
I don't know how into this you want to get. But if your going in hot and heavy, just take everything out of that truck. If it doesn't need it to make the truck move, ditch it; all it is is added weight. Move the engine back a few inches, help balance the truck out. Put a fuel cell in the very back of the bed. Move the battey to the back, ect.
Put a rollcage in that thing and 4pt harness!!!!!!! Trust me
Good luck and have fun!
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 12-28-2003, 03:38 AM   #3
ACES
Life is a gamble
ACES's Avatar
If you end up going through with it. I would love to see the progress pictures!!!
1970 Orange CST C-10 w/350, posi, Longbed
The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine.
-- Ralph Waldo Emerson
ACES is offline   Reply With Quote
Old 12-28-2003, 12:15 PM   #4
my68beatertruck
GOT JACK???
my68beatertruck's Avatar
http://www.fabtechmotorsports.com/ht...d73_87c10.html
68 C-10 250", 200R-4, LWB
04 F350 dually V-10, 6-spd
72 Cadillac Coupe DeVille
my68beatertruck is offline   Reply With Quote
Old 12-28-2003, 12:22 PM   #5
my68beatertruck
GOT JACK???
if you're going for pure pre-runner style, lose the inner fender wells, bed floor and lighten the truck as much as possible!! get high arched springs, (lift or 3/4 ton springs, and soften them up by losing a leaf or 2. quad shock the front end. one shock is on the outside of the spring, i think you can fit another on the inside of the spring!! i have heard of people doing this on c-10's, but never saw it myself. body lifts are bad. roll bars are good. lock the rear with the trusty MIG welder and hit the trails!! i've done a 4X2 ranger in this style, and it romped with a 4 banger!!
Old 12-29-2003, 01:29 AM   #6
bigbluthng
bigbluthng's Avatar
this is my buddy's toyota 4runner. used to be 4wd but has since removed all the 4x stuff. if you only want a couple inches then maybe taller coils and lift blocks fit the bill. if you are serious about the ride quality then maybe long travel a-arms with coilovers and a 4 link out back with coilovers would suit you better. contact fabtech (www.fabtechmotorsports.com) or camburg engineering at www.camburg.com
bigbluthng is offline   Reply With Quote
Old 12-29-2003, 02:13 AM   #7
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
Heres a pic of a blazer, non shur of the lift.
GMC JUNKIE TOO is offline   Reply With Quote
