Old 11-13-2021, 08:33 PM   #1
Bullzak_83
Mystery Hole
70 CST10
This hole in the firewall was it for the clutch?,if you had a standard. Another hole I have not noticed until today. Someone had put duct tape over the hole at one time on the inside. Just curious what it was for, and does any one know where I might be able to get a rubber plug that might cover it up?
Thanks.
Bullzak_83 is offline   Reply With Quote
Old 11-13-2021, 08:35 PM   #2
kwmech
Re: Mystery Hole
Factory had a metal plate over the hole with just 2 screws (top and bottom) holding it in place
Old 11-13-2021, 10:08 PM   #3
dmjlambert
dmjlambert's Avatar
Re: Mystery Hole
I believe 67 and later had a plastic plug like this
https://www.classicindustries.com/pr...ts/152862.html
And 72 and earlier had a metal plate like this
https://www.classicparts.com/1971-72...ctinfo/90-542/
Supposedly the plastic plug would pop out and get lost if you closed the door with windows up, so they switched to metal plate held by screws in some year, perhaps 71.
I got a metal plate for my 1969 truck that surely came with the plastic plug, because there are no screw holes. I plan to install it the next time my engine is out. The later year trucks also got a vent in the door frame to allow for the doors to be shut with windows up without causing them to be hard to close.
Plastic plug
Name:  Screen Shot 2021-11-13 at 8.03.40 PM.jpg
Metal plate
Name:  Screen Shot 2021-11-13 at 8.04.01 PM.png
dmjlambert is offline   Reply With Quote
Old 11-14-2021, 05:11 PM   #4
Classic Bowties
Always on the hunt...
Re: Mystery Hole
Here is a firewall clutch rod delete id picture detailing the above early style plastic plug vs. later metal plate subject. If needed, we can get one of these 67-70 clutch rod delete plugs packaged up & headed your way, details are listed in the below linked parts board thread. Mel
https://67-72chevytrucks.com/vboard/....php?p=8906175
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
