Old 11-15-2021, 04:55 PM   #1
jchav62
1962 C-10
jchav62's Avatar
1974 C10, mystery vibration
Hi all! It's been a while since I posted on here. I have a question:
I recently acquired a 1974 C-10 longbed and got her back running and on the road. The issue I'm having is a weird vibration. What happens is I can drive the truck and it will run super smooth for about 10, sometimes 20 miles.... then some weird vibration starts. My first thought was the driveshaft center carrier bearing. Replaced that. Took for a cruise and it seemed to fix it... around mile number 15 of the test drive, the vibration came back?
Any ideas? I'm kind of stumped.. can't think of anything that will start vibrating only after a few miles of driving...
Thanks! JC62
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 11-15-2021, 06:21 PM   #2
69Tom
69Tom's Avatar
Re: 1974 C10, mystery vibration
U-Joints?
69Tom is offline   Reply With Quote
Old 11-15-2021, 06:47 PM   #3
jchav62
1962 C-10
jchav62's Avatar
Originally Posted by 69Tom View Post
U-Joints?
That's what my buddy and I were thinking. Just wanted to get other opinions since it only happens after a few miles of driving.... not constantly.
Thanks...
Joseph Chavez
Old 11-15-2021, 06:55 PM   #4
GOPAPA
GOPAPA's Avatar
Just a thought .,, I had a vibration in my old Chevy car and first thought it was the tranny and then u joints and it wound up being my rear end,, pinion gear and spider gear ..the car did not do it all the time and mainly after I got it going awhile
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 11-15-2021, 07:08 PM   #5
69Tom
69Tom's Avatar
Would that be the pinon bearing going bad, or did someone get in there and didn't shim it to correct specs? Not a bad thought though.
I'd definitely start with u-joints, however, as it's an easier fix. I actually just shortened my 74 C20 and dropped off my drive shaft for shortening, new u-joints, and balancing. The u-joints definitely had not been replaced in my truck, so it was time.
Old 11-15-2021, 07:15 PM   #6
GOPAPA
GOPAPA's Avatar
I'd definitely start with u-joints, however, as it's an easier fix. I actually just shortened my 74 C20 and dropped off my drive shafted for shortening, new u-joints, and balancing. The u-joints definitely had not been replaced in my truck, so it was time.
Just gone bad and by accident showed up at the same time as I was over hauling the tranny ,,and I had the drive line shortened and balanced too,,so it through me what the heck was causing the vibration ,,,
I jacked up the rear end and started the car and looked at the rear end while it was running and seen that it was vibrating at that point.
Old 11-15-2021, 07:46 PM   #7
Dead Parrot
Tires getting warm and changing a bit. Especially if they are mixed set.
One set of brakes pads/shoes rubbing until they get hot.
Differential with not enough oil and getting warm after several miles.
Intermittent vibrations are a PITA.
Dead Parrot is offline   Reply With Quote
Old 11-16-2021, 10:04 AM   #8
geezer#99
geezer#99's Avatar
I chased a vibration kinda like that on a 76 sb.
Did everything possible. New tires, rims, u-joints, balanced driveshaft, wheel bearings, steering box, all of the suspension parts. Everything I could think of.
I thought I had it fixed several times until I’d hit a bump or turn around in the street.
Turned out to be a cracked frame. Right by the steering box. Covered in grime and impossible to see.
Check your frame.
Old 11-16-2021, 12:41 PM   #9
jchav62
1962 C-10
jchav62's Avatar
Thanks guys! The diff oil is one of the first things I checked. It was full and looked pretty clean. I also went and bought new brake shoes for the rear... will be putting those in first chance I get... along with u-joints.
I just got a "new" steering box as well. That's on the 'to-do' list for this weekend. I will inspect the greasy frame when I do that. To me it feels like the vibration is in the rear, but you never know.
I'll post up my findings... if I ever find it.
Joseph Chavez
Old 11-17-2021, 06:21 AM   #10
Corts60
Just here to tinker
Corts60's Avatar
Hey glad to see you’re back!
Rear brakes my friend. One or both of the shoe sets is probably sticking when it heats up. Just went through this on my 86. Tool me a couple weeks to figure it out. Go run it until it acts up again and then jack up the rear end in neutral and hand spin the wheels to see which one is sticky. you’ll probably find the culprit right away.
Old 11-17-2021, 11:36 AM   #11
jchav62
1962 C-10
jchav62's Avatar
Hey bud! I plan on getting out there this afternoon...hopefully. I have the new shoes. I hope that does it! I'm looking forward to driving the truck. She feels real solid for the most part. Thanks!
Joseph Chavez
Old 11-18-2021, 02:31 PM   #12
Corts60
Just here to tinker
Corts60's Avatar
Let us know how it goes. Just FYI, my truck was doing this with brand new pads on. I never had that happen before on all my trucks. I guess I set the initial adjustment too tight.
Old 11-19-2021, 08:23 AM   #13
LT7A
Good info here.
Old 11-19-2021, 01:06 PM   #14
jchav62
1962 C-10
jchav62's Avatar
I went to put in the new rear shoes.. upon removal of the left rear drum, the brake adjuster and related springs/parts all fell out! That was the problem... got the new stuff in and we're good to go!
Thanks all for the advice!! Have a great Thanksgiving...
Joseph Chavez
Old 11-19-2021, 05:26 PM   #15
Corts60
Just here to tinker
Corts60's Avatar
Ha! That’ll do it. Glad you got her all fixed up!
