Old 11-15-2021, 08:49 PM   #1
MD2020
MD2020's Avatar
Under cab Battery box
I need a under cab Battery box, NO hole in the floor.
Where can I get one?
MD2020 is offline   Reply With Quote
Old 11-15-2021, 08:56 PM   #2
Rickysnickers
Rickysnickers's Avatar
Re: Under cab Battery box
Here's one example, https://www.brotherstrucks.com/1947-...tinfo/DDBT059/
Old 11-15-2021, 09:10 PM   #3
_Ogre
_Ogre's Avatar
definitely put remote boost points under your hood if you do that
shop air compressor timer
Old 11-15-2021, 10:40 PM   #4
MD2020
MD2020's Avatar
Do those drop down ones rattle?
Good idea on the Remotes
Old 11-15-2021, 11:20 PM   #5
mr48chev
mr48chev's Avatar
I have no idea if they would rattle or not. You see photos of street rods with them once in a while but to me they aren't practical. The remote boost points would be an absolute must if you had them though. My BMW 528 has the battery in the trunk, absolutely no place under the hood to hook jumper cables and the only place on the engine means that you have to jack and block the car up and slide under it and hunt for that spot to hook the cable to. When the battery is dead, the trunk won't open and the other way to jump it is crawl though the back seat into the trunk and hook jumper cables or the charger to it.
With that I would really question the wisdom of putting the battery under the cab in a a spot that required jacking the truck up to have any access to it. There are plenty of batteries that are designed with setups that allow them to vent under the floor of cars when they are installed under the back seat. The battery for a 2000 Cad Deville DTS isn't very tall but can be had in a pretty high amp rating. Same with one for an Audi 5000 from the 80's. One could be placed in a box behind the seat and be out of the way and out of sight but pretty easy to access when needed.
My ongoing truck projects:
Old 11-16-2021, 09:03 AM   #6
youngrodder
youngrodder's Avatar
I used 2 of these drop down battery boxes on my last 2 builds. You can find more inexpensive ones on eBay. They do not rattle.
I too purchased some remote terminals. I didn't end up using them because I lucked out. The side battery terminals are directly in line with the gap between the body and the running board when the battery is in the up position. I have it hooked up to my battery tender from there.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-16-2021, 09:10 AM   #7
youngrodder
https://www.ebay.com/itm/26496844165...oAAOSwImRYYwkD
Old 11-22-2021, 10:06 PM   #8
1project2many
I am happy to discuss problems with "under the van" battery boxes. Accessibility, lifting/lowering battery, difficulty in cleaning terminals and battery top, difficulty in replacing cable ends... But if you want one I would think a box that has an access panel on the long side combined with a side terminal battery might be ok. We use slide-out trays for many of our vehicles but they are not right for most vehicles.
This is an example of a Ford OEM frame-mount battery box. Very difficult to work with:
GM did a little bit better:
On most of our vehicles, accessible battery or not, we have switched to something like this:
1project2many is offline   Reply With Quote
