Old 12-27-2003, 08:32 PM   #1
Martin64
Martin64's Avatar
Battery Drain Problem
I have a small power drain in my '70 that I'm trying to narrow down. It drains the battery in about 36 hours. What are all the items that have direct power besides the light switch and starter? I'm thinking my ignition switch may be the problem but I haven't had a chance to test it yet. When I dosconnect the battery I can hear something "click".... open relay? What relays stay hot (direct powered) on the firewall?
There is no stereo or amp or anything like that installed so that's not a problem.
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 12-27-2003, 08:41 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
other than ignition switch and headlights is the cigarette lighter brake lights and maybe the horn im betting its in the ignition tho
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-27-2003, 08:43 PM   #3
cdowns
cdowns's Avatar
the horn relay is hot all the time
best thing to do is remove 1fuse at a time using a test light to see where the drain is
Old 12-27-2003, 09:17 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
does your horn work? It is the first place I go when I have a battery drain. It has been the problem more times that it hasn't.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 12-27-2003, 09:18 PM   #5
Martin64
Martin64's Avatar
No cigarette lighter and the horn is disconneted (because it stuck on me once.....that was funny/embarrassing). The brake light does stay on sometimes but I'm now in the habit of checking it when I get out of the truck...... thanks again gents for the help!
Martin Gibson
USAF Retired
1964(-ish) C10
Old 12-27-2003, 09:31 PM   #6
Martin64
Martin64's Avatar
What does the "Transmission Spark Control" relay do and is it a direct wire?
Martin Gibson
USAF Retired
1964(-ish) C10
Old 12-27-2003, 09:53 PM   #7
john
member #16
john's Avatar
Did you just unhook the horn wire or unhook the power to the relay? The relay can still drain power if it is the prob. The TSC relay could be another source. If it is not working I would just unhook it. good luck The TSC allows vacuum advance only in high gear. John
john is offline   Reply With Quote
Old 12-27-2003, 10:00 PM   #8
Martin64
Martin64's Avatar
Good point about the horn, I hadn't thought about that..... when it stuck on me I just figured it was stuck at the horn button on the steering wheel and when I couldn't get it off quick enough I just pulled over and unhooked it from the horn. So since it's still "hot" and grounds through the bracket that still completes a circuit.
Martin Gibson
USAF Retired
1964(-ish) C10
