Old 11-17-2021, 02:31 AM   #1
Bob Q
‘83 Voltmeter Questions
Just finished up doing the LMC tach conversion in my ‘83 K2500 6.2L. Took it for a ride this evening to double check everything before putting the instrument bezel back on. Tonight, the factory voltmeter starting reading high (15-16 volt range) just before the red zone on the upper end. It’s never read that high and I’ve never had any issues with it up until tonight. I checked the batteries with a multimeter and they were about 12.7 volts with the engine off and about 14.5 volts with it running and the gauge was still reading high. Do you think the voltmeter is going wacky or is there something else that could make it read higher all of a sudden even though the charging system itself seems fine?
Thanks.
Bob Q.
'83 K2500 6.2L
Bob Q is offline   Reply With Quote
Old 11-18-2021, 10:06 AM   #2
Bob Q
Re: ‘83 Voltmeter Questions
Anyone have any thoughts on this one?
Bob Q.
'83 K2500 6.2L
Old 11-18-2021, 11:36 AM   #3
Wgesnerjr
Wgesnerjr's Avatar
One thing to keep in mind that the accuracy of the stock gauges was not that precise. However if it is reading high after the tach install, I would think that has more to do with it. Since your testing of the battery and alternator showed no issue, I would start with checking the power at the gauge and see if it measures the same as the alternator/battery. if so, I would say the gauge is not accurate. Might also check the grounds at the dash to make sure they are clean. Poor grounds have been known to do weird things.
hope this helps.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 11-18-2021, 01:47 PM   #4
JJH Jimmy
JJH Jimmy's Avatar
Did you mess with the resistor on the back of the volt meter? If the resistor is not there the meter will peg.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 11-18-2021, 11:31 PM   #5
Bob Q
Thanks for the tips. Nah, I didn’t mess with that resistor or anything with the gauge. Just seemed to start reading high all of a sudden. I’ll check the grounds.
Bob Q.
'83 K2500 6.2L
Old 11-19-2021, 11:08 AM   #6
Bob Q
I checked/cleaned grounds and cleaned connections at the alternator, no change in the gauge reading. Took voltage at the output of the alternator and it's around 14.95-15 volts. Might pull the gauge next.
Bob Q.
'83 K2500 6.2L
Old 11-20-2021, 03:57 PM   #7
Pontiac1976
Pontiac1976's Avatar
If everything check out you can take your Alt in for a test
shop to make sure the regulator is not over charging. If it test good I would think the gauge might be having trouble since the tach up grade. Hum maybe out there but is the tach drawing more power load then it should.
14.95-15 volts.
your #'s seem about right. things to look at how old is the Batt did it de-charge from the time you did the work, are you still running 35AMP none A/c or the 55AMP A/c stock alternator or have you up graded. If you had up graded the alternator and still had some bad connection found some that ATL may read a little higher.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 11-21-2021, 01:51 AM   #8
Bob Q
Yeah, I’m going to take the alternator into a shop for a test on Monday morning.
Thanks for the tips about checking the batteries. I had kept the batteries on a charger when I was working on it, so I don’t think they got too discharged. The alternator is a 78 amp AC Delco rebuild that’s been in there for a few years.
Bob Q.
'83 K2500 6.2L
Old 11-21-2021, 06:57 PM   #9
hatzie
Moderator
hatzie's Avatar
If it's a GM gauge you either have a loose calibration resistor on the volt gauge canister or the alternator is really putting out that many volts.
If the gauge is part of the LMC kit I'd lean toward a bad gauge.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 11-24-2021, 03:55 PM   #10
Bob Q
It’s the original gauge. I took the alternator to a shop and it was putting out 15-15.5 volts, so they put in a new regulator and it’s now at 14.7, but the gauge is still reading high at the same place. I’m going to throw another voltmeter in to see how it reads.
Old 11-27-2021, 01:21 AM   #11
Bob Q
Took the alternator to a shop and it was putting out too much voltage. They said it was actually putting out about 15.5 volts, but should be around 14.7, which it is now after they replaced the regulator. So, I figured this was my whole issue. Nope. I put the alternator in and the voltmeter gauge still read high, just like before. I got a new OEM-style voltmeter and it now reads lower and closer to the actual voltage. Seems like all is good now. Thanks again for all your help.
Bob Q.
'83 K2500 6.2L
Old 11-27-2021, 10:57 AM   #12
LT7A
Glad you got it worked out. Thanks for posting how you fixed it.
