Blue 67
Front shock options
Hi:
What are you guys using for front shocks in stock setup? I can't find any performance or heavy duty brands for stock setup replacement. Thanks
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
Re: Front shock options
Reply deleted. I saw your truck is a 3/4-ton so my suggestion may not work.
1951 Chevy Panel Truck Last edited by MiraclePieCo; 11-18-2021 at 02:09 AM. |
if you have the stock number go to monroe.com shocks site and either cross reference or look in the catalog for what you want. i only new the length and approximate travel when i flipped my axle on top of stock springs. i looked thru the monroe catalog until i found a shock that worked
cool, an ogre smiley Ogre's 58 Truk buildhow to put your truck year and build thread into your signature shop air compressor timer |
![]() Join Date: Jul 2007
A Monroe 5826 is the "regular" shock for a 53 3100, 3600 or 3800.
MONROE 5826 Specifications Dust Shield Yes Extended Length (in.) 16.375 Upper Mounting Description Stem Mount - 2.3/8" Stem Length X 3/8"-16 Thread Pitch Lower Mounting Description Stem Mount - 2.3/8" Stem Length X 3/8"-16 Thread Pitch Compressed Length (in.) 10.125 Travel Length (in.) 6.250 Parts Pack(s) P01134 Cylinder Included No Compressed Bumper Stop No Extended Bumper Stop No Extended Hydraulic Lockout No Dust Shield Material Metal Stud on each end plus the extended and compressed lengths should get you there. Lots of years of selling and installing shocks says that 75% of the time you really don't want a heavy duty shock unless you are doing heavy duty driving.
Blue 67
Thank you guys.
I saw some Monroe and Gabriel on rockauto. I was just wondering if there are other option such as Bilstein or Koni. What I was thinking was since I am stuck with my front solid axle due to being 8 lug, I want to be the best shock that I can for driving point of view.
The Gabriel shock is about an inch longer
https://gabriel.com/product-search/l...?partnum=81270 Koni doesn't list a 53 truck and some of the listings that the Gabrial page above show don't work on the Koni page. Rancho is a waste of time KYB doesn't show much either. They most likely have something on the line of what you are/were thinking of but you will have to get into the size charts and using the info from the Monroe page start hunting.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 11-19-2021 at 01:13 AM. |
3/4T truck will ride like a truck regardless of what shock you put on there
my 1T 59 panel didn't have shocks in the back from the factory, no mounts i could barely get my pinky between the tire and the fender, it never rubbed
In my mind you can't go wrong with QA-1 adjustable shocks for performance. Give them a call and they will most likely be able to fix you up.
| Bookmarks |
