laying low
![]() Join Date: Mar 2001
efan add
1991 C1500. I'm giving thought to swapping from stock clutch fan to an aftermarket e fan. Could I tap into one of the stock coolant temp sensors wires to signal the fan controller, without affecting the temp gauge or the ecm?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver 'primer is finer' Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
![]() ![]() Join Date: Jul 2002
Re: efan add
I would think you would need the ecm to trigger it. Putting a double load onto the input of the ecm will probably alter things and effect the gauge. I am just guessing with theory, I never tried one or saw one that didn't have its own temp sensor for the fan.
![]() Join Date: Dec 2009
Re: efan add
This guy has got a 3 part video.
That might give you some idea's. Link: https://www.youtube.com/watch?v=fLIMYkCqBYc
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Re: efan add
Nope.
You will have to add a temperature on/off switch in a water passage. The existing is a sensor, not an on/off switch. |
laying low
Re: efan add
Oh that was entertaining.
Sensor instead of switch. Yes I can see that. Well it's something to think on. Thanks
Re: efan add
You need an aftermarket fan controller. Some of the ECMs have the ability to control fans by adding code, but if you're not familiar with burning chips then the aftermarket controller is the way to go.
Mike Last edited by sntrym95; 11-21-2021 at 09:47 PM. |
laying low
Re: efan add
I've got a cheap after market controller out there. But I did just put on a new fan clutch today so I'll see how it runs. I'm not impressed with the low cfm the after market efans produce though. So I'm on the fence. I don't think this radiator is wide enough to use a later year factory dual fan setup or I'd go that way. Just to be clear, I don't have an over heating issue. I'd just like to go efan to let it warm up faster and run quieter. The OE fan clutch may have been the original and it was locked up non stop creating a lot of noise and engine drag.
| Bookmarks |
