![]() Join Date: Mar 2010
NP205 Transfer Case Parts
This is a cross post to the ad I have up on the 1973-87 board.
Please post interest in an item on that thread (see link below) I do have a few items that are specific to the pre '73 NP205's so I'm including them on this board as well. http://67-72chevytrucks.com/vboard/s...d.php?t=827708 PayPal fees included, but not shipping fees. Early ('69-70?) Manual 205 shifter with machined pivot bushing. The bushing was used with a 3/8" regular style hardware bolt on some of the early adapters (TH350 & SM465) I've seen, but the shifter can also be used with the newer style pivot bolt if your adapter has the correct threads, or you drill and tap it. Shifter is primed and painted, but has plenty of chips and flaws so it will need to be repainted - $175 Flat style S-Link with patent date $30 ea, $20 for the one missing a stud. $40 ea for the round style started ~1971 Shift rail cross bar/bracket - $20 ea Includes the early style hook from the shift rail if you want it. The shift rail is shot, but the hook can be removed and welded to a new/good shift rail. 1972 NP205 ID plate and screws - $20 Side mount 205 support bracket set. 2 available, one is '72 and earlier, the other is '74+ Both need new rubber bushings and hardware, but are complete otherwise. I have the 2 large bolts to go into the 205 that will be included. Your choice -$40 If you have interest in an item post it in the other classified. I'm going to go in the order received. The picture size is reduced to meet the max size requirements of the forum, but I can send additional pics if you want; just let me know. I also have 10 spline outputs, yokes, and plenty of other parts for NP205s in the other listing. |
| Bookmarks |
