Old 11-25-2021, 07:45 PM   #1
kglowacky
aftermarket a/c
I am getting ready to decide if I should buy an aftermarket a/c system or go with the original set up. Have done a LS 1 swap (and have the new compressor installed) and so a retrofit will be needed if I stay with the old system. The question is what would be better I am going to spend money either way. In the past I have not had good luck with a Vintage air set up and another brand in my other builds. Would like to hear some current owners of these aftermarket systems thoughts. I live in Houston and it needs to be cold. Thanks
kglowacky is offline   Reply With Quote
Old 11-27-2021, 08:51 PM   #2
Bloodhound
Re: aftermarket a/c
I have Vintage Air and I have no complaints. Well worth it for the money in my opinion. What problem did you have with yours?
Bloodhound is offline   Reply With Quote
Old 11-28-2021, 01:22 AM   #3
mikentosh
mikentosh's Avatar
Re: aftermarket a/c
I’ve done two builds with vintage air, and then the last build we retrofit factory AC into a non-AC cab using R134a with a parallel flow condenser. I definitely prefer the factory setup as it’s much quieter and can pull fresh air from the cowl…and properly setup it blows just as cold as vintage air. Factory system can be totally overhauled for less $$$ than vintage air, but definitely takes a lot more work and research to do right.
mikentosh is offline   Reply With Quote
Old 11-28-2021, 02:05 PM   #4
kglowacky
Re: aftermarket a/c
my experience with Vintage air was it would not cool the cab. in a small 46 chev pu. The cab was fully insulated and still couldn't keep up. The next was a 56 wagon same results. Not good here in Houston.
Old 11-28-2021, 06:02 PM   #5
karlbenz
Re: aftermarket a/c
I been looking at this https://www.classicautoair.com/shop/...ioning-system/
Oooops wrong forum
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 11-28-2021, 06:45 PM   #6
kglowacky
Re: aftermarket a/c
Been out of the market for a few years. Is $1500 the going rate for a aftermarket a/c system.
