Old 11-26-2021, 04:15 PM   #1
79vette
Re Key Locks
I want to re-key my 88 R30 and my 79 Corvette to use the same key used in my 86 K5. My keyring is getting too fat, and I dont want to split it up because I know I'll lose them all if I do.
The K5 has an aftermarket lock set that use the GM "A" key for all doors, tailgate and ignition.
The Corvette has the original locks, with an A keyed ignition and B keyed doors
The R30 has "D" keyed doors, and I cannot read a mark on the igniton key but its definitely different from the A key in the other vehicles.
Does anyone know if the letter on the key matches geometry cast into the inside of the lock cylinder? IE for the R30 and Corvette, do I need to get new lock cylinders to accept the A key? I suspect thats the case, but dont want to just buy parts I dont need.
Also, does anyone have a source for the wafers, springs and bezel parts for these locks? Or do I need to pull locks at the junkyard to strip for parts or go to a locksmith?
1988 "Crane Truck" C30 - 350, SM465, with a 15' knuckle crane - thread
1986 M1009 - 6.2 Diesel, SM465, 2 speed aux trans, NP205 - thread
1979 Corvette - 350 T5
1977 Jimmy - 350, TH400, NP203
1982 Blazer - 350, 700R4, NP208 - Totalled, now a parts truck
Scratch built 16' flatbed trailer - thread
79vette is offline   Reply With Quote
Old 11-26-2021, 04:23 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Re Key Locks
Maybe Lockdoc will see this. AKA Leon
Calling Lockdoc
You could send him a PM.
I can totally understand the fat key ring problem.
I am trying to eliminate a few of my keys to trailers and buildings myself.
The early bird gets the worm,
84 Chevy K-20
Old 11-26-2021, 04:32 PM   #3
79vette
Re: Re Key Locks
I'll PM LockDoc if he doesn't see this, thanks!
Also yeah, once i fix the cars I want to retrofit GM door lock cylinders into my trailer toolbox and the homemade center console in my K5 (currently uses a paddle style trailer door latch). "One key to rule them all" is the goal.
Old 11-26-2021, 05:02 PM   #4
ron350
ron350's Avatar
Re: Re Key Locks
Something else to consider is keying the door locks to match the ignition key. That way each vehicles keeps its own ignition key but you loose 3 door keys from the key ring.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 11-26-2021, 05:18 PM   #5
79vette
Re: Re Key Locks
I could do that as a fallback if I'm not able to find the parts, but I would really just like to have one key that I can use for all my vehicles and eventually for my trailers and tool boxes.
I don't plan to ever sell any of these vehicles, but if I do I could pull the lock cylinders and install them into a replacement vehicle to keep the matching key set up
