Old 12-27-2003, 10:58 PM   #1
1972ChevyGuy
1972ChevyGuy's Avatar
Stereo Hooked Up But Need HELP!
Ok, i bought http://sm.crutchfield.com/cgi-bin/S-...=0&cc=01&avf=N .... I got it all hooked up/wired fine and dandy until i try to play it without the truck on. Works with truck on and with key partially to right, but not on acc. What should i change to make it work on acc. I have one wire that stays hot all the time for my clock and the other goes dead when the truck is off.
1972ChevyGuy is offline   Reply With Quote
Old 12-27-2003, 11:08 PM   #2
Randy70C-10
Randy70C-10's Avatar
You need to figure out which wire is hot when the key is in the acc position and split the red wire into that wire.
Randy70C-10 is offline   Reply With Quote
Old 12-27-2003, 11:19 PM   #3
1972ChevyGuy
Randy, your a genius and I'm dumb, lol. Didn't even think of that. All these posts persuaded me not to cut my doors and put speakers in so I kind of rigged up something for now. I built a box under both sides of the seats with 2 6X9s on the outside and 2 6.5s on the inside of each box. Put a 8" sub in the middle cause space was CRAMPED! Not really the best looking job but BOY does it sound better than my broke old 1 speaker cassete player
Old 12-28-2003, 12:04 AM   #4
Andy4639
Old member
Andy4639's Avatar
Question Fuse Block
Why not tie into fuse block? Take a test light and see what is on with the key in accessaries.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-28-2003, 03:20 AM   #5
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Tie your main power wire into the slot on the fuse boxed marked"radio".
It's hot with the key "on",key in "acc" postion and off when the key is off.
You'll need to tie into the "BAT" slot with one of your wires to keep the presets.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 12-28-2003, 11:29 AM   #6
cdowns
cdowns's Avatar
yep i think that idea of hooking it into the radio slot is a good idea
Old 12-28-2003, 05:15 PM   #7
1972ChevyGuy
Thanks for the replies, but my FB does not have a "radio" slot The PO switched the boxes and nothing i labeled and I do not have a clue where the box came from. Good thing I have a Fluke and got it figured out. I appreciate the help guys - Jeremy
Old 12-28-2003, 06:11 PM   #8
gunnersm8
i think i used my lighter wire for the hot.
gunnersm8 is offline   Reply With Quote
