Old 11-28-2021, 01:38 PM   #1
697498chevy
1969 C 10 driveshaft carrier bearing
After 27 years the rubber in mine is pretty mushy . I see Rock Auto sells just the rubber insert . I plan to replace the whole thing , just curious if anyone has replaced just the rubber insert ? THANKS !
697498chevy is offline   Reply With Quote
Old 11-28-2021, 03:07 PM   #2
Wrenchbender Ret
Re: 1969 C 10 driveshaft carrier bearing
I used to replace the rubber only years a go when I had a shop. Its better to replace the whole assem. as they are not all that expensive. You can spin the brg & see if it is quite. If so you can just replace the rubber.
Wrenchbender Ret is offline   Reply With Quote
Old 11-28-2021, 03:19 PM   #3
697498chevy
THANKS Wrenchbender ! The whole thing is like $30 , I was just wondering .
Old 11-28-2021, 06:02 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I just bought one for my C20 from NAPA. It was $43.00. They had a $17.00 one but it looked pretty crappy.
LockDoc
Leon
Old 11-29-2021, 03:57 PM   #5
697498chevy
THANKS Lockdoc . I'll probably get mine at NAPA too .
Old 11-29-2021, 05:53 PM   #6
697498chevy
See online NAPA has 2 . One's $27 and one's $60 . I'll check them out soon . Just pulled the driveshaft a min ago . Thanks
Old 11-29-2021, 08:34 PM   #7
LockDoc
LockDoc's Avatar
I didn't write the numbers down but he had 3 different ones shipped in and let me choose the one I wanted. One was $17, one was $43, and one was $45. I didn't see any difference between the $43 one and the $45 one. He had to look them up in the catalog instead of on the computer.
LockDoc
Leon
Old 12-01-2021, 01:20 PM   #8
697498chevy
Thanks again , Lockdoc . I just pulled the driveshaft bearing with my puller . Plan to take it to NAPA in the morn and see what they have . So far , so good .
Old 12-02-2021, 04:37 PM   #9
697498chevy
The $60 bearing looked better , so I got it . NAPA HB206FF . Came with 17 mm bolts . Probably the only thing metric on my truck . Haven't fully tightened them as the rear tires are off the ground . Anyone know if it really matters ?? THANKS !
Old 12-02-2021, 11:37 PM   #10
LockDoc
LockDoc's Avatar
Shouldn't matter. The slip joint will take up any slack.
LockDoc
Leon
Old 12-03-2021, 12:21 PM   #11
697498chevy
Thanks Lockdoc ! I did manage to squeeze under when I took it off the stands and tighten the 17 mm bolts . Been out for a test drive and everything seems good !
Old 12-04-2021, 07:21 PM   #12
LockDoc
LockDoc's Avatar
Good deal. Drive the wheels off of it...
LockDoc
Leon
