Old 11-29-2021, 01:18 PM   #1
69Tom
69Tom's Avatar
A/C bracket bolt question
Have a question for you guys. All the bracketry was removed from my engine for the stock A/C system prior to my ownership. Stock 74 454 truck. Since sourced said brackets, now I need bolts to connect them.
Are the threads in the heads and block to mount the brackets fine or course threads? They seem to be coarse, but I didn't want to screw up the threads by tightening in my test bolts (I still need to get the correct lengths)
Also, should I go with grade 8 for strength or 5 so there's some slight flex so they don't just shear off due to potential vibration?
Thanks.
69Tom is offline   Reply With Quote
Old 11-29-2021, 01:22 PM   #2
MJN
MJN's Avatar
Re: A/C bracket bolt question
They're all coarse thread and grade 5 bolts will be more than strong enough.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 11-29-2021, 01:25 PM   #3
69Tom
69Tom's Avatar
Thank you!
