Old 12-28-2003, 12:14 AM   #1
CRRoy71
New 2.5" lift on.
Here are a couple of pics of my new lift, and a before pic. The after pic will follow tomorrow.
Chris
'92 ext. cab s/b 4.3L "Sparky"
'04 crew cab 2500 4x4 6.0L
CRRoy71 is offline   Reply With Quote
Old 12-28-2003, 12:15 AM   #2
CRRoy71
Before lift.
Chris
Old 12-28-2003, 12:16 AM   #3
CRRoy71
Another
Chris
Old 12-28-2003, 07:53 PM   #4
CRRoy71
Here is an after pic. It lifted exactly 2".
Chris
Old 12-29-2003, 12:08 PM   #5
85 K5
Looks Good!
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock
http://www.oplnk.net/~spirit/K5front.jpg
85 K5 is offline   Reply With Quote
Old 12-29-2003, 04:16 PM   #6
Gregsmx
Gregsmx's Avatar
CRRoy, that mild lift looks real good. Could you do me a favor and measure from the ground to the bed of the truck at the tailgate? Also, what size tires are on the truck.
I think my Blazer also has a 2" lift and I'm trying to verify this.
Thanks, Greg.
'75 Blazer RAT 4X4 "BLAZIN" - Custom frame off
Here's the website I'm uploading pics to: Greg's frame off project
Gregsmx is offline   Reply With Quote
Old 12-29-2003, 06:58 PM   #7
bigblock73
yeller
bigblock73's Avatar
Looks good, will it still fit in the garage?
bigblock73 is offline   Reply With Quote
Old 12-30-2003, 12:25 AM   #8
CRRoy71
gregsmx, I will try to get that measurement tomorrow for you, and those are 32" tires.
bigblock73, it still fits barely. I thought I was going to have to let some air out of the tires to get it out.
Chris
Old 12-30-2003, 08:26 PM   #9
85 K5
Are you getting any driveline vibration now? Mine does, 2-2.5 lift and 33" tires. Had to drop the transfer case, put the bolt mounting spacers between the crossmember and the frame.
Old 12-30-2003, 09:33 PM   #10
CRRoy71
gregsmx, I have 53" from the ground to the top of the closed tailgate. I hope that's what you meant.
85 k5, I am not getting any vibration at all. It rides real good.
Chris
Old 12-30-2003, 11:59 PM   #11
Gregsmx
Gregsmx's Avatar
CRRoy, thanks for the measurement. I must have a bit more lift. I'm 53.5" with 29" tires. That would calculate to a 4" lift. But there is no blocks on the lift and only 1 additional leaf on the front spring and rear. I'm not sure how that much lift can be in my truck with just an add a leaf.
This is verified as the height from the ground to the bed is 34". A K-10 (4wd) shows to be 29 1/4" in the manufactures' specifications.
85K5 the vibration you feel in your seat when you accellerate hard out of the hole is due to the fact that your drive shaft to axle angle was at too steep an angle after the lift. If you'd like to put your XFER case bushings back in the correct location, you can insert a wedge shaped spacer between the leafs and the rear axle, giving the axle a canter or angle that will raise the u-joint coupler upwards thus reducing the angle between the axle and the drive shaft.
Ideally, there should be a small angle between axle joint and drive shaft, just enought that under hard accelleration, the axle angle will diminish to 0 or close to it.
Hope this is helpful, Greg.
Old 12-31-2003, 09:15 AM   #12
85 K5
Thanks for the info, Greg. Sorry to have hijacked the post. The severe angle is at the transfer case. I have tapered blocks which make the driveline almost straight with the axle, as you said it should be. It's ok like it is, sometimes I think I see too much hanging down underneath for a normal stance. Vibration was not only during acceleration but also at freeway cruising speeds, starting at around 40-45 mph. No vibration like it is now.
Old 12-31-2003, 03:46 PM   #13
useRc10
useRc10's Avatar
i have a 2" lift and fit 33/12.5 tires
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 01-19-2004, 01:30 AM   #14
cochino12
It followed me home?
cochino12's Avatar
maybe I missed it in your post, do you have a shackle lift in the rear or did you use a block?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-19-2004, 01:36 AM   #15
CRRoy71
Adam, if you are asking me, I put new 2.5" springs all the way around.
Chris
Old 01-19-2004, 04:46 PM   #16
IoWnZa
Big Block Blazer
Look's very nice.
I have no lift and have 32x11.50's and they fit with plenty of room. I made sure and tested out a pair a friend had before I went w/o a lift. I just don't want to ruin my gas mileage worse then it already is.
/IoWnZa
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys]
IoWnZa is offline   Reply With Quote
Old 01-27-2004, 07:12 PM   #17
cochino12
cochino12's Avatar
CRRoy71 can you tell me how tall your truck is now? I have a new 4" and thinking I will go with a 2" so I can fit in the parking garage. I think I missed the size of your wheels, I see you are running 32" tires though. Would you mind posting a pic of your truck from the front? Thanks
Adam
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-27-2004, 09:59 PM   #18
CRRoy71
Adam, Overall I am at 6'4" with 15" wheels.
I will go out tomorrow and get a front pic for you.
Chris
Old 01-27-2004, 11:43 PM   #19
cochino12
cochino12's Avatar
thanks for the measurements. Where did you get the 2" springs? all I can seem to find are 4" or add a leafs
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-28-2004, 09:58 AM   #20
CRRoy71
I got mine from here. I called them and got to talking to the guy, who also had an 86 Blazer, and got it cheaper than the website prices.
Chris
Old 01-28-2004, 12:46 PM   #21
cochino12
cochino12's Avatar
Are your wheels 15*8 or 15*10?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-29-2004, 02:29 AM   #22
CRRoy71
They are 15x8, here are the pics.
Chris
Old 01-29-2004, 02:30 AM   #23
CRRoy71
another one.
Chris
Old 01-29-2004, 02:51 PM   #24
cochino12
cochino12's Avatar
thanks for the pics and measurements chris
Adam
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-29-2004, 06:06 PM   #25
CRRoy71
You are welcome.
Chris
