Old 12-03-2021, 01:40 PM   #1
mike in mo
speedometer trouble
im trying to buy a new speedometer for my 1989 gmc suburban but all the aftermarket places stop at 1987 when i ask them most say they have no idea if it will work in a 89 or not .
anyone know of a replacement that works or is the 1987 listed the one that works up to the 1991 body change?
mike in mo is offline   Reply With Quote
Old 12-03-2021, 02:33 PM   #2
Wgesnerjr
Wgesnerjr's Avatar
Re: speedometer trouble
It may be that Chevy switched from cable over to electric. Not sure what year that happened but that may be the reason.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 12-03-2021, 03:03 PM   #3
Just call me Sean
Just call me Sean's Avatar
Yes that's the reason. 89 is electric.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 12-03-2021, 07:09 PM   #4
Corts60
Just here to tinker
Corts60's Avatar
88 is the last year of cable driven I believe. At least my 88 Suburban is cable driven anyways.
Old 12-04-2021, 12:20 AM   #5
mike in mo
my 87 crew cab is electric. did they use both?
Old 12-04-2021, 12:44 AM   #6
Just call me Sean
I thought 87 and up is electric, because they're fuel injected so the computer also gets the signal.
Old 12-04-2021, 01:30 AM   #7
roboticjunky
My 87 was cable driven, but there was a speed sensor built into the back of the speedo. Then the wires went to the VSS buffer and then to the ECM since the truck came with TBI.
roboticjunky is offline   Reply With Quote
Old 12-04-2021, 01:33 AM   #8
roboticjunky
Here's what I was talking about.
Old 12-05-2021, 01:58 PM   #9
THI
THI's Avatar
1989 was still cable driven so 1981-1987 will work. 1990 went to VSS driven because of the Rear ABS.
THI is offline   Reply With Quote
Old 12-06-2021, 08:35 PM   #10
Pontiac1976
Pontiac1976's Avatar
THI is got the years right.
But it not unheard of the very late last of the run on the line having a few changed early to the new part some times when they short the old ones.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
