![]() Join Date: Oct 2012
patina question
I am building a 1965 c10 patina. My drivers side fender is really rough Should I cut out the bad and patch then primer or just bolt it on. Here is a picture of the truck and the fender.
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
Re: patina question
I'd be tempted to fix the rust, go a bit smoother on the wrinkles, and then fauxtina it back.
![]() Join Date: Oct 2009
Re: patina question
that's a bit beyond patina, I'm with Billy.
Re: patina question
That is what I was thinking as well
![]() ![]() ![]() Join Date: Jan 2018
Re: patina question
I'll third Billy. Since you already have to fauxtina the rockers, the fender would look better that way too
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Re: patina question
Thanks. I have a patch panel ordered
