Old 12-28-2003, 03:23 AM   #1
500HP/SB
please don't break
500HP/SB's Avatar
how to remove steering arm?
I have a '70 k10 with a dana 44 and a 4in lift. i had another front end that had a raised steering arm. i didn't know about the cone shaped things on the bolts. i couldn't get the arm off this front end, i ended up using a torch to heat it up and break it loose. now i have the raised arm but i need to get the stock one off my truck. i don't want to take a torch near my brake lines and all that stuff. What is the correct way to remove a steering arm?
thanks
70 k10 35s 350/sm465/np205
titanspeed.com
500HP/SB is offline   Reply With Quote
Old 12-28-2003, 03:48 AM   #2
1tonswb
1tonswb's Avatar
Get a sledge hammer and beat the steering arm until you see that its moved a little bit. Then take a small standard screwdriver and stick it in the slot on the tapered washers and "unscrew" them. Thats how I do at at work.
1tonswb is offline   Reply With Quote
Old 12-28-2003, 07:45 PM   #3
ljbear
ljbear's Avatar
Yep, BFH and a little heat
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 12-28-2003, 10:42 PM   #4
DaHateTank
Thumbs up
they've got ya covered. BFH got mine off...
Ya gotta hit it HARD!!
-M
DaHateTank is offline   Reply With Quote
Old 12-28-2003, 10:49 PM   #5
Destructo
I'm gonna take a swing in the dark hear and assume that "BFG" means "Big Fawking Hammer"?
Destructo is offline   Reply With Quote
Old 12-28-2003, 11:00 PM   #6
playtoy1
yep use lots of break away, wd 40 what ever your brand you use and the biggest hammer you can swing heat does help alot but can screw up a upper balljoint
playtoy1 is offline   Reply With Quote
Old 12-29-2003, 12:21 AM   #7
500HP/SB
please don't break
500HP/SB's Avatar
great thanks guys, mabee i'll try it out tomorrow
titanspeed.com
Old 12-29-2003, 12:37 AM   #8
rogf4
Have to agree with the guys above BMFH and a half a can of WD-40 and alot of elbow grease
rogf4 is offline   Reply With Quote
