12-06-2021, 03:30 PM | #1 |
64 vs 66 e-brake
Hello,
I'm in the process of cleaning up a 66 short frame with the intention of moving my 64 body over. I see the e-brake assemblies are different. My 66 frame has the rod through the frame on the passenger's side, but it's in pretty rough shape and I can't seem to find any other parts to rebuild this. So, figured the 64 brake works and I have new 64 cables, I'll just move the crossmember over. I haven't taken any measurements yet to drill holes, but did notice a set of holes close to the crossmember position on the 66 frame. Then noticed they're is an extra set of unused holes (possibly matching the 66, again I haven't measured) on the 64. I'm just curious what those extra holes are, and is there any reason I can't just move the 64 crossmember over to the 66? Or are the 66 parts available somewhere and easy to replace? I had no idea there were some many little differences in the 64-66 trucks till I started this. Thanks! |
12-06-2021, 06:41 PM | #2 |
Re: 64 vs 66 e-brake
Shoot me a PM. Have some E brake parts so probably would be able to help you out some at least.
12-07-2021, 12:29 AM | #3 |
But Found Her 25yrs Later!
66 ebrake system is considered better.
Here is a good thread: http://67-72chevytrucks.com/vboard/s...d.php?t=527022
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
12-07-2021, 12:36 AM | #4 |
And here is a place for reproduction parts.
https://www.lmctruck.com/1960-66-che...g-brake-cables
12-07-2021, 12:48 AM | #5 | |
Also, I had been looking at the LMC diagram, but it only shows the cables for the 66. I need the hooks, and my guide rod is pretty mangled. In that thread someone mentioned 67-72 parts are all the same as 66. LMC sells a guide kit for 67-72. So, figure I'll get the guide kit and different cables and see what I can do. Edit: I measured the cable brackets on my tubular arms. That are the same as the brackets on the original 66 arms. So, I think I'm good. I'm curious how the 67+ guide rod from LMC attaches, since the original 66 is riveted, but I think I'll go ahead and order and find out. Thanks. Last edited by closer9; 12-07-2021 at 01:09 PM. |
12-07-2021, 03:33 PM | #6 |
Cant remember if for LWB or SWB or if they are the same?
12-07-2021, 04:24 PM | #7 |
I think, from what I've read, the only difference in LWB and SWB is the intermediate cable.
Upon closer inspection, I see the piece on the end of the long rod is pinched preventing it from coming off the rod, which then allows the rod to slip out of the frame. I'm sure that is the only reason I still have it on this frame. 😄 Last edited by closer9; 12-07-2021 at 04:52 PM. |
12-07-2021, 04:30 PM | #8 |
closer9: Please remember that you must be a Premium member to post WTB adds
DPowers: Please remember that PM sales are prohibited. If you are offering up the parts to closer9 for free, that's ok though. Thanks!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
12-07-2021, 04:33 PM | #9 |
Of course. Dont think that a WTB or PM sales are happening here though.
12-07-2021, 04:45 PM | #10 |
Good deal, thank you. I might've been a little pre-emptive with my comment
12-07-2021, 04:52 PM | #11 |
On my 66, the cable seemed a little loose and I couldn't get the slack adjusted enough with the stock adjuster. So I replaced that rod with a piece of all-thread and a couple nuts & washers, and just tightened it to take up the slack.
12-07-2021, 04:56 PM | #12 |
I wasn't looking to buy anything here. Just wasn't sure how the two differed. It appears from another thread that what I need is available new, I just wasn't look in the right place.
LostMy65, that's what I was first considering when I saw the mangled rod in my 66 frame. 😀👍 |
12-07-2021, 09:19 PM | #13 |
Looks like you can get the 66-72 e-brake stuff new here also:https://www.classicparts.com/1966-72...tinfo/71-770/#
12-07-2021, 10:40 PM | #14 |
Thanks! I sure thought I checked Classic Parts, but didn't see that.
Edit: it was Classic Industries I checked. |
12-24-2021, 12:43 PM | #15 |
One more quick question... there is a bracket on the driver's side. Somewhat tapered with maybe a 1/2" hole, 2 rivets in the frame, maybe 8" long. My 64 has it, but not being used. 66 has it as well. I've seen pix of it being used as an exhaust hanger. Is the the original purpose?
