12-12-2021, 10:16 AM | #1 |
Leaf spring plastic shims
How many do you put between the springs just one on to and one on bottom.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
12-12-2021, 10:26 AM | #2 |
Re: Leaf spring plastic shims
I don't recall having plastic shims in my stock springs, but all they do is reduce noise. I would think you would need one in front and one in the rear of each leaf that rubs against another leaf.
I wish Tuff Country did install these, because twice a year I have to spray WD-40 on all my springs to keep the squeaks away. |
12-17-2021, 03:12 AM | #3 |
Guessing OP is referring to the thin shims on the axle pad and under the u-bolt plate. I really do not see a purpose for the plastic shims, mine were chewed up. You could leave them out and be fine. I will not be using any on my new rear springs. But yes, from factory my truck had one on spring pad and one under u-bolt cap.
These old trucks never had sliders in-between the leaf ends.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 12-17-2021 at 05:06 AM. |
12-17-2021, 09:59 AM | #4 |
Carpe manana
I used the spring liners by Speedway motors ( https://www.speedwaymotors.com/Flat-...ners,7471.html ) to replace the OEM examples on the top and bottom of the spring pack (two per spring). These did seem to "cushion" the ride on my K20 enough that I went back and added them to my Blazer. I recommend the product.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
12-17-2021, 10:17 PM | #5 |
Thanks for the help I thought they had one on the bottom and one on the top just wanted to make sure.
12-18-2021, 12:56 PM | #6 | |
How do they stay in place? website says "edge lip keeps it in place", but not sure what they are referring to. |
12-18-2021, 01:47 PM | #7 |
Depends on the leafs style. Some use continuous straps, and some use buttons on the ends.
I highly recommend them since they allow the leaves to slide against each other easier. Plus give the leaf a more progressive spring rate because of the reduced drag or friction. |
12-18-2021, 05:46 PM | #8 | |
Carpe manana
Example photos of original pieces: https://67-72chevytrucks.com/vboard/...14&postcount=1
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 12-18-2021 at 05:50 PM. Reason: Added |
