12-12-2021, 04:21 PM | #1 |
lowering advice, tips, packages for my 70 c10
I'm looking to lower my 1970 c10. I'd like to just use drop springs for now. How low can/should I go with just doing drop springs. Would love to hear what packages you guys suggest and any pics of what my ride height will coming out looking like. Thank you
Just a 25yr old trying to learn |
12-12-2021, 05:28 PM | #2 |
Re: lowering advice, tips, packages for my 70 c10
This truck has 2 inch dropped spindles and 1" springs in the front with 5" dropped springs, shock relocators and adjustable panhard bar in the rear. It rides great.
I you try to do 3" in the front with springs, you will sacrifice ride quality.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
12-13-2021, 02:01 PM | #3 |
Mos def get shock relocation brackets. You don't want your rear shocks laying at a 35-40 degree angle, but much closer to 90 degrees. Maybe a panhard bar relocation too. Get the No-Limit stuff.
12-13-2021, 02:48 PM | #4 |
12-13-2021, 04:55 PM | #5 |
The ones I posted above do not require removal of rivets. They do require a cobalt bit to drill through the frame. I highly recommend new ubolts too.
12-13-2021, 10:36 PM | #6 |
70+ ( Old Skool Club )
I have a set of 2 1/2 inch drop spindles and 4 inch rear drop springs with an adjustable panhard bar and rear shock relocators ready to go on my truck in Spring. Just put the 255/60 17 TT2's on in August and just want the slighty lowered look for the truck. The 17's andtires are only .18 inches higher than the 235/75 15's that have been on my truck since I bought it.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
12-13-2021, 10:40 PM | #7 | |
Truck looks good. What size tires you running? OP the 3 front, 5 rear is pretty standard with minimal changes. If you want just springs I have seen some spring kits that are 2" front and 4" rear. |
12-13-2021, 11:28 PM | #8 |
Senior Moment
This is the same way I went before going with coil overs. Some need a C Notch some not. The adjustable pan hard is a must also
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
12-13-2021, 11:34 PM | #9 |
I did a 2.5" front cut spring (1 ring) on the front and Jeep TJ springs in the back for 4 " of drop . Search on this forum and you can find the home made shock relocators for front and back not hard to fab. My truck rides like a dream and will haul a decent load allso but I dont use it for that a cruiser street brawler mostly.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
12-14-2021, 02:32 PM | #10 | |
Is it still stock drum brakes or have disc brakes been swapped?
12-14-2021, 04:40 PM | #11 |
Dig the wheels. what are they?
