door not locking correctly
Hi, I got my truck painted a few years ago, replaced the locks ,anyway, after i lock the drivers side , i can push the handle in several times and the door will eventually unlock by itself...what would cause this? any ideas? its scary that its not very secure.....any help would be appreciated
Re: door not locking correctly
You are locking the door with the key aren't you? You have to use the key to lock the doors. If so try pushing in on the door while turning the key to make sure the lock goes all the way into the locked position.
![]() Join Date: Jul 2008
Had a similar problem with my truck. I wasn't able to find the cause, but did find that if I attached a spring inside the door to always keep constant "down" or locking direction on the lock button mechanism, the door would stay locked. An imperfect solution, but as you said, scary that it's not secure otherwise.
Try pushing in on the door as you lock it. See if problem persists.
#5 | |
thanks guys, I do push in on the door while locking it, guess ill try the spring like 67 Carry all did.....
The Older Generation
Check this thread out. Your problem isn't exactly the same but I think it could still cause what you are experiencing. http://67-72chevytrucks.com/vboard/s...d.php?t=741123 LockDoc
thanks Leon,i'll bet that's the problem
No problem.
LockDoc
