12-14-2021, 07:29 PM | #1 |
1965 3 speed manual questions
Hello all
My 65 has been whining real bad and popping out of gear very often while driving. So I have been on the lookout for a rebuilt trans for it. I found one within reasonable distance for a couple hundred bucks that came out of a restored 1965 pickup with less than 1000 miles on it since rebuild. I went and got it and have been looking it over and it turns out that it is a Saginaw 3 speed with a longer tailshaft than the Muncie that is in mine. It looks like the linkage might be difficult to make work. Also I've been reading posts on here and seeing things about a 3 speed Saginaw with overdrive. Pictures of what I bought have been attached. Any help would be appreciated. Thanks!! |
12-14-2021, 09:19 PM | #2 |
Re: 1965 3 speed manual questions
Yes, to swap that transmission into your 65 you'll have to have the driveshaft shortened and make some changes to the shift linkage.
A few years ago, we swapped a Saginaw with overdrive into Dad's 66. On his, the driveshaft needed to be about 5-1/2" shorter ... I think yours (even though it doesn't have overdrive) might be the same, but measure to be sure. We also had to swap the slip yoke ... old one was coarse 16 spine, newer trans needed fine 27 spline. On the shift linkage, we were able to use the existing 2nd/3rd rod without any modifications. But the 1st/reverse rod had to be lengthened about 3-1/4" like Sizemore 65 did here --> http://www.67-72chevytrucks.com/vboa...hp?t=711857%22 We also had to do a little bit of trial & error re-bending of the 1st/rev linkage rod to avoid interference with the outer end of the clutch fork when shifting into reverse. |
12-14-2021, 10:12 PM | #3 |
Just a question why not rebuild the one in your truck that was making noise?
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
12-15-2021, 02:33 PM | #4 |
I was going to rebuild it but then this one popped up and I made a mistake thinking it was the same transmission that was in my truck. I will go ahead and just rebuild the original now. Where is the best place to buy the bearings and seals, or the gears of they turn out to be worn?
12-15-2021, 04:48 PM | #5 |
12-15-2021, 08:52 PM | #6 |
If it were me I would do gears and all. I rebuilt a ford 4 speed with bearings and synchronizers and after a little bit it started jumping out of 4th gear. Then bought all new gears and bearings and synchronizers. No more problems Lesson learned I had to pull it twice.
12-15-2021, 09:31 PM | #7 | |
12-18-2021, 08:48 AM | #8 |
I just went through all of this on my old muncie 318. Lots of rebuild kits if you have the tools and know how. I had it done by a local pro who does them for the racers. Be careful not to over tighten the bearing retainer. Mine has a hairline crack and leaks a bit. Guy who rebuilt mine said it was already like that but I had no choice. Extremely hard to find. I finally found one after I installed it so now waiting to do my clutch and will have it done then. I found some parts guys if you need help.
01-24-2022, 09:22 PM | #9 |
So far no luck finding anyone that has the synchros. Any other recommendations for parts suppliers. I feel like I've done an exhaustive search and struck out everywhere. Any help would be appreciated 👍👍
01-24-2022, 09:49 PM | #10 |
01-24-2022, 09:54 PM | #11 |
Looks like you need PN 3774720 for the 2nd-3rd syncro assembly. Maybe you can find a NOS one out there?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-01-2022, 08:40 AM | #12 |
Hi, one piece of advice, if you haven’t checked it already - be sure that the pilot bearing in the crank is good. I had a 66 three speed years ago. I went through a bunch if transmissions before I checked the pilot bearing, which had a lot of wear. Once I replaced it, problem solved. Good luck with it.
