12-16-2021, 01:14 PM | #1 |
Removing spray paint off original paint
Has anyone got spray paint off original paint without
Damaging paint ??? Ideas or help?? |
12-16-2021, 01:42 PM | #2 |
Re: Removing spray paint off original paint
Rubbing compound followed up by some wax
12-16-2021, 01:51 PM | #3 |
I would wet sand the spray bomb off with wet-or-dry sandpaper...as fine as your patience allows. I would start with 3000 grit and see how fast it comes off. This is as fine as I use before buffing a paint repair anyway. You will want to pay close attention to your sanding and keep it on the spray paint you want to remove. If you don't stay on the spray paint (which you will end up sanding some of the original paint around and under the spray bomb for sure) you will be removing original paint and that risks sanding through to the primer...= bad.
If the 3000 grit is trying your patience, step down to 2000 grit, but only rub that until the spray paint is really thin, but not gone...then step back to the 3000 grit. Depending on the shine/oxidation of the original paint...3000 grit may be all you need, but if not, you would then use some Fine Scratch Remover buffing compound to bring the shine back to where you want it. The sanding and the buffing should all be done by hand (no power tools). It takes time, but can be done. Hopefully your "spot' is small. Tip: I use a short piece of a paint stirring stick that is about 2.75" long with the sand paper as a sanding block. For larger, more flat surfaces...find a nice flat stirring stick. For smaller areas the need alot of attention to detail...I use a shorter piece that is cupped (not flat, but warped) and make sure the convex side of the stick is being used against the paint. Oh, circular motion is best.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
12-16-2021, 04:36 PM | #4 |
Guess I should have specified...it's the firewall and booster etc..
Sanding is not an option... I've tried a easy off acetone Goof Off I guess I'm more use aerosol stripper and not let it sit very long |
12-16-2021, 06:32 PM | #5 |
If the booster is cad, I would use lacquer thinner on it.
I screwed up and didn't paint the top of my dash before I set my cab on the chassis. Now I have quite a masking job ahead of me.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
12-16-2021, 07:05 PM | #6 |
Active Member
Brake fluid will take the spray paint off and any paint under it
12-18-2021, 02:22 PM | #7 |
Oven cleaner works well to remove it.
12-18-2021, 07:06 PM | #8 |
Lacquer thinner and a light scotchbrite or 000, or 0000 steel wool....but you will remove paint that lies beneath it, if there is any.
12-18-2021, 07:53 PM | #9 |
Moderator
I used lacquer thinner and a rag to remove spray paint off of some doors. I was careful and it did not damage the original paint underneath. It could have also been really cheap spray paint that someone used.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
12-18-2021, 08:21 PM | #10 |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
12-18-2021, 08:35 PM | #11 |
Denatured alcohol works on some spray paint.
It is not as hard on old cured paint.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
