Old 12-16-2021, 01:53 PM   #1
clay68c10
clay68c10's Avatar
A quality alternative for H4 glass headlight housings
I found a really nice semi old-school headlight option for anything with 7" headlights.
I originally bought them as an upgrade for my Jeep and they are so good that I picked up a second set for the C10.
These are quality glass housings, with good H4 bulbs, AND a pre-made relay harness.
You can order them thru your local Toyota dealer, or online. Generally they cost around $50ish if you shop around.
Part # 81110-60P70
Here's a link to an install on a TJ Jeep.
https://wranglertjforum.com/threads/...ght-mod.55959/
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 12-16-2021, 01:56 PM   #2
clay68c10
clay68c10's Avatar
Re: A quality alternative for H4 glass headlight housings
Some pics on my Jeep, the C10 is still in project mode
13 Tahoe LTZ
Old 12-16-2021, 01:57 PM   #3
clay68c10
clay68c10's Avatar
And the beam pattern from about 10ft
13 Tahoe LTZ
Old 12-16-2021, 03:11 PM   #4
jimijam00
Thats a good alternative. I paid more for these.
jimijam00 is offline   Reply With Quote
Old 12-16-2021, 03:52 PM   #5
clay68c10
clay68c10's Avatar
Those were plan A, then I found the Yota lights.
13 Tahoe LTZ
Old 12-16-2021, 04:03 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
My ancient Cibič fell apart.
Got a Hella h4 to replace
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 12-17-2021, 10:23 AM   #7
Toro
Toro's Avatar
subscribed
Toro is online now   Reply With Quote
Old 12-18-2021, 07:51 AM   #8
I have heard of the Jeeps stuff being used. Found these in the 60-66 area of the board. Toyota H4 kit is supposed to also be good and it comes with harness and all to do conversion.
https://cruiserteq.com/oem-toyota-ko...kit-w-harness/
Haven't got them on the 70 yet, but hopefully will get to it soon.
Palf70Step is online now   Reply With Quote
Old 12-18-2021, 10:48 AM   #9
clay68c10
clay68c10's Avatar
Yes, it comes with a nice relay harness. It’s the Toyota upgrade for the FJ40s
13 Tahoe LTZ
Old 12-18-2021, 12:26 PM   #10
Joyridin
I am not a fan of headlights with the cutoff beam half way through the light. I understand it helps cars in front of you and coming towards you, but I like the full headlight.
Joyridin is offline   Reply With Quote
Old 12-18-2021, 01:18 PM   #11
Greasey Harley
Greasey Harley's Avatar
That's fine, you can get get brighter lights that still have a good beam pattern and no cut off. The problem is when the lights are poorly engineered (read cheap), they can become more problematic for oncoming traffic.
Lights that are 1000+ Lux with a poor beam pattern and no cutoff are not just annoying to everyone else, they are dangerous.
Don't be that person.
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 12-18-2021, 03:36 PM   #12
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
I bought Dapper OE7 with their 7" OE Glass upgrade. Cheap they are NOT, 100% satisfied I am. I even had a problem with one, getting a replacement bulb was easy as pie.
Forum review here (by fastpace) http://67-72chevytrucks.com/vboard/s...d.php?t=801372
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 12-18-2021, 03:58 PM   #13
Fbks_Cruiser
Fbks_Cruiser's Avatar
The cutoff doesn’t mean they are putting out less light. Wattage is the same. The difference is that the light beam is more focused and actually puts more light on the road surface. Why waste light up in the trees instead of on the road?
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 12-18-2021, 04:08 PM   #14
70STOVEBOLT
70STOVEBOLT's Avatar
Do you have a pic from the front, outside at night?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 12-19-2021, 07:12 PM   #15
MikeB
MikeB's Avatar
Yes, there's a lot of crap out there, especially the HID conversions.
I'm not sure we can still get Cibie 7" headlamps anymore, but the Hella stuff is very good, especially the European (not DOT) spec lenses. And you can always go to higher wattage bulbs as long as your wiring can handle the additional current.
I also have to comment on the bluish bulbs. Blue light disperses like crazy, and while it can be seen from a long distance, it's terrible for lighting up the road in front of you, and just pisses off oncoming drivers.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-19-2021, 07:34 PM   #16
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Agreed as to HID conversions in housings designed for Halogen bulbs -- not good at all. Same with blue bulbs, I wish they were never made. They should be illegal, and that law should be strictly enforced.
As to 7" Cibie headlamps, I have had them for decades and love them. I prefer their beam pattern to Hellas. Yes, they are still available at Amazon of all places.
https://www.amazon.com/Cibie-82440-H...s%2C140&sr=8-1 and https://www.amazon.com/Cibie-082440-...s%2C140&sr=8-2.
Not sure why they are listed twice but it's the same item from the same seller at the same price. The second listing calls them fog lights (maybe for legal reasons?) but they are dual-filament H4 headlamps.
Also, note that the second listing does not state that bulbs are included.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-19-2021, 08:03 PM   #17
KQQL IT
At the body shop.
KQQL IT's Avatar
That's awesome. I should have researched those a bit more.
I suppose if the Hellas ever get broken i'll get some of those.
Old 12-19-2021, 08:12 PM   #18
Bigdav160
Bigdav160's Avatar
Wow, those Cibies have gone up $$ a lot since I bought them in 2017
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 12-19-2021, 08:22 PM   #19
MDFarms
So these replace the old school headlights for a correct fit.
MDFarms is offline   Reply With Quote
Old 12-19-2021, 08:39 PM   #20
Jason Banks
Jason Banks's Avatar
I was going to get the Hella for the truck I'm building but I got the Holley Retrobrights.
https://www.holley.com/products/exte.../parts/LFRB135
Haven't tried them yet. Might put them in my other truck just to try them out...
That Toyota stuff looks like a hell of a deal!
Jason Banks is offline   Reply With Quote
Old 12-19-2021, 09:02 PM   #21
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yes. I have installed my 7" Cibies in at least three different vehicles without any issues. As with any headlamp (even stock), a relay upgrade is a plus.
- Mike -
RIP El Jay
Old 12-19-2021, 09:13 PM   #22
KQQL IT
At the body shop.
KQQL IT's Avatar
The Hellas have a similar light pattern as the cibie.
But I grew up with cibie in everything we had.
Maybe have to get a pair. :/
Old 12-19-2021, 09:15 PM   #23
MDFarms
What Relay do you recommend?
Old 12-20-2021, 01:13 AM   #24
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I don't -- there are different ways to do it, and you should use a method that you are comfortable with. There's plenty of threads here to search through and see what others have done. There are kits already made up and some guys prefer that. I went to a local parts store and got Bosch-style fused relays. I have plenty of wire & connectors and I soldered up a harness.
- Mike -
RIP El Jay
Old 12-20-2021, 07:43 AM   #25
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I wish they still made those Wrangler RT tires. They work great off road...
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
