wheel options
I have a '88 GMC V3500. Purchased with Cepek Hummer H1 wheels (16.5x8.25, 7" offset).
The big offset works because the truck still has dually axles (Dana 70 rear and Dana 60 front). I don't have a spare and want to move away 16.5" wheels anyway. Questions: What are my options - should I look at H1 wheels with similar offset in 17" (these seem expensive)? A friend suggested custom wheels made by someone like Detroit Steel Wheels - anyone done this? Is there a simple option for modifying the axles/hubs to make more conventional offset wheels a better option? |
Re: wheel options
That’s an awesome red beast!
What type of tire do you want? What type rim too? I checked on cepec site and it’s 2 grand for 4 17 inch rims. Ouch! |
Re: wheel options
Thanks man.
I'm looking for a 35-37" tire (AT OR MT). My thought is 16 or 17 - so it will be easier to find tires and have options. The wheels are less important - just want something simple. Yeah, I think anything is hummer tends to be expensive. |
Re: wheel options
After a little research, I'm starting to second guess myself.
The 2-piece hummer OE steel wheels along with a PVC bead-locker is something that I can mount a tire in my driveway without a tire shop (and without ether/fire). That is a definite benefit but would mean sticking with 16.5" tires. I may want to go with 2 piece hummer steel 16.5 wheels. The question is whether the supply of surplus 16.5 tires is going to dry up in the near future. |
Re: wheel options
Good possibility 16.5’s will be extinct.
Found some factory alloy 17’s for you. If you google original manufacturer rims there are more than just these guys. https://www.originalwheels.com/humme...h22009rims.php |
Re: wheel options
I've got a set of 16x10 Series-82 Wheel Vintiques rims in good condition that I'd consider selling, if you'd consider conventionally offset rims.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
Re: wheel options
The DRW front hubs can be machined into SRW hubs. Look for posts on Pirate4x4.com for what it takes. In the rear, running a single wheel on the dually rear gets you close to same track width as front, 1” wider on either side but finding a SRW rear axle not that hard.
Re: wheel options
16.5 HUMVEE tires can be had cheap surplus new and used. Just get a HUMVEE wheel and tire for a spare and keep what you have. Check Colony Tires in Carolina. The supply of surplus Goodyears and BFGs will not be going away.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
| Bookmarks |
