12-17-2021, 10:55 AM | #1 |
67 C20 rear coil to leaf conversion
Hi All. Looking for some engineering drawings for rear leaf spring hanger locations for a 2 WD longbed 67 C20. All the drawings I have come across only show coil spring frames or 4X4 leaf frames.
I want to convert my coil springs to leaves but need to know the specific location of the spring hangers on the frame. Any help would be greatly appreciated.
John 1967 C20 2WD Longbed 2001 2500 HD 4X4 Extended cab long bed |
12-17-2021, 11:58 AM | #2 | |
The Older Generation
Re: 67 C20 rear coil to leaf conversion
I have a pair of leaf spring frame rails out behind the shop I might be able to measure later. I am making cookies so I can't go out right now. There are drawings of the frames in the chassis service manuals. The measurements are a few pages back from the drawings. You might check on that. If you don't have the manuals you can download them here: http://67-72chevytrucks.com/vboard/s...d.php?t=558016 Big thumbs up to member "hatzie" for posting these...... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-17-2021 at 12:05 PM. |
12-17-2021, 12:13 PM | #3 |
Doc, thanks for your reply. I have the GM chassis manuals for 1967 and 1970 C10-30 series trucks and they only show the coil spring rear frame or 4X4 frame with leaves. Those pictured on this forum are the same ones as the ones in my manuals.
John 1967 C20 2WD Longbed 2001 2500 HD 4X4 Extended cab long bed Last edited by Mickeymotormount; 12-17-2021 at 01:28 PM. |
12-18-2021, 01:18 PM | #4 |
OK, lets see if I can make this understandable.... I had to measure from the rear of the frame since the front is cut off. This is what I came up with. From top rear corner of frame rail to top set of rivet holes: 11 5/8 - 16 1/2 --- 63 7/8 - 70 1/8. From bottom rear corner of frame rail to bottom set of rivet holes: 11 9/16 - 16 11/16 --- 63 7/8 - 68 1/8 .
12-18-2021, 03:15 PM | #5 |
Post Whore
An inquiring mind wanting to know why the conversion?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
12-18-2021, 10:09 PM | #6 |
Doc, thanks for taking the time to take a pic, measure and post the dimensions for me. They will help a lot.
As for the inquiring mind, I plan on running 19.5s on the truck. Leaves will make sure there are no clearance issues. My trailing arms are also rotted out. Rather than replace them, I will change the coils out to leaves. I have always preferred the ride of the leaves over coils in my trucks anyway.
12-18-2021, 10:59 PM | #7 | |
No problem. If you need any other measurements let me know. Once you get one of the holes drilled in each bracket and a bolt installed you can clamp the brackets in place and use a transfer punch to mark the rest of the holes in each bracket. I recommend drilling them out so a 7/16 inch bolt fits snug in the hole. I use grade 8 bolts for that type of application. LockDoc
12-20-2021, 11:52 PM | #8 |
What leaf spring hangers are you using?
72 Chevy C20 86 Silverado Shortbed |
12-21-2021, 04:13 PM | #9 |
I was planning on buying new springs, shackles and hangers.
Hopefully I can find a set specific for 67-72 Chevys.
