Old 12-28-2003, 02:39 PM   #1
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
Choke trouble
I have a Holley carb that I recently installed, and I got a new 4" K&N filter for Christmas to nest on top of it.
Since installing it my electric choke does not work?? Besides checking for the 12 volts from the ignition is there any checks I can do to figure out what is wrong with it??
It worked until I installed the filter, but it must just be a coincidence??
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 12-28-2003, 06:46 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Check first to make sure the throttle blades aren't being interfered with by the new filter housing.If the air filter is the only change that is the most likely problem.
The other thing is to check and be sure no wires or vacuum lines were unplugged when you installed it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-28-2003, 08:00 PM   #3
DanoDMano
DanoDMano's Avatar
The filter isnt in the way. I removed it and I cant move the blade physically at all. It seems to be hitting on the arm that kicks the idle up at cold start. Could it just be an adjustment to the choke?? Can I just rotate the choke to get it to work??
Power Locks,
Truck Photos
Old 12-29-2003, 12:10 AM   #4
rage'nrat638
rage'nrat638's Avatar
well pushing the gas pedal set's the choke...so pull the throttle lever back and try to move the choke linkage....if it move's it's not stuck.....need to adjust this while the choke spring is cold....
you do have 12volts to the choke coil????
if so try turning the choke housing to increase the choke adjustment clockwise....
this will make the choke stay on longer and make it have to heat-up every time you turn the engine off.....
turn it back for less of this effect....
rage'nrat638 is offline   Reply With Quote
Old 12-29-2003, 12:15 AM   #5
DanoDMano
DanoDMano's Avatar
Thanks rage'nrat638 Thats what I needed. I did move the throttle linkage and it still does not move. I adjusted the choke but now the choke keeps the throttle at about 1000 RPM.
So if I go CCW with the choke housing then it will reduce this effect??
Power Locks,
Truck Photos
