Senior Moment
![]() Join Date: Mar 2002
Do Wheel Tubs have Gaskets???
I’m replacing my Rear Wheel Tubs. It looked like there was some sort of gasket material between the tub and Bed. What would I use if anything when going back together
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
![]() Join Date: Jan 2021
Re: Do Wheel Tubs have Gaskets???
I did the same thing with my truck, I used 3m seam seal. Just lay or form it where it needs to be and mount the new tubs in. Start all the bolts and tighten the bolts little by little, back and forth. Thanks Chuck
Posted via Mobile Device |
Senior Moment
I figured on using something like that Was just curious if someone made a gasket or if metal to metal would be Ok
No you don’t want metal on metal, need to seal it to keep water, dirt etc out. Thanks
![]() Join Date: Dec 2014
You would commonly use welting for putting together stepside boxes, in particular, and I think it would be a good idea for your application too. Something like this is what you are looking for, I think.
https://www.speedwaymotors.com/Speed...sket,1221.html
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
