12-18-2021, 06:37 PM | #1 |
Antenna removal
Do I need to remove the fender to get to this damn antenna?
1963 C20, small window, long bed 292, 4-speed |
12-18-2021, 06:44 PM | #2 |
Revitalizing a 6T C10
Re: Antenna removal
There are 4 bolts ( i believe (2) 9/16 and (2) 1/2 inch)
I ended up opening the door, and using a long extension to reach the two that go into cowl ducting and the last two from the hood side Cowl by Keith, on Flickr
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side. 350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs 20+ year long term project in process Lots of Rust, more memories... |
12-18-2021, 06:59 PM | #3 | |
Re: Antenna removal
Thank you!
12-19-2021, 07:04 PM | #4 |
Re: Antenna removal
Curious as to if you're deleting it or replacing it. If you are deleting it, I found that a "knock out" plug from a metal electrical box is a darn near perfect size circle for welding in the hole.
12-19-2021, 11:47 PM | #5 |
Re: Antenna removal
I think I’m going to replace it. Not sure where to get one though.
12-20-2021, 12:27 AM | #6 |
Re: Antenna removal
I bought one of these generic ones that has been working pretty well, and doesn't look too far out of place
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
12-20-2021, 11:14 AM | #7 |
Re: Antenna removal
The aftermarket parts places sell reproduction or generic antennas
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
12-20-2021, 04:41 PM | #8 |
Re: Antenna removal
Back when I replace mine I put in one that will telescope so that it will fit under my cover. I think I got it at pep boys.
