12-19-2021, 12:56 PM | #1 |
Neutral safety switch
70 cst10
Does anyone have a ideal where I could mount a NSS. I bought a switch for the column in the truck which is a tilt, went to install and no place to mount it. Yep the column does not have a mounting hole for the switch. I've looked online and seen some that mount to the trans (TH350) by the way. Has anyone came across this and came up with a solution? |
12-19-2021, 05:01 PM | #2 |
Re: Neutral safety switch
This will work only with a stock pan.. It's an "either/or" application, not both.
https://www.summitracing.com/parts/lok-bl1400u |
12-20-2021, 01:18 AM | #3 |
hi,i just did a tilt column for my truck,from a Class A motorhome.the NSS was on the column but in the wrong place.i cut a new "notch" for the switch and then welded the piece i cut out for the new notch,in the old notch,finished it off and painted it.looks fine.not that hard to cut.these aren't great pictures,i realize.if you need something better,give a holler.take care.Greg
12-20-2021, 01:34 AM | #4 | |
