![]() Join Date: Apr 2021
Rear mounted stainless tank question?
Doe's anyone know who makes a fuel line kit to go from engine back to a Boyd's aluminum fuel tank with the 340 Stealth fuel pump? Any pictures or options? My truck came with a brand new from GM 350TBI Engine and I decided to run with it rather than moving things for a LS and proper 4x4 shifter location. The plan is to use all SS Brake lines from INLINE Tube so fuel line In SS would be great as well.
#2 | |
I ended up going with Fragola stainless steel braided PTFE fuel hose I put together myself (it has a black plastic coating so the braid doesn’t rub against anything). First time putting fuel lines together like this and was apprehension initially doing it but took my time and it all turned out great and no leaks…super clean look in my opinion. Posted via Mobile Device |
#3 | |
Re: Rear mounted stainless tank question?
Thanks for the reply!! |
![]() ![]() Join Date: Jan 2005
sstubes.com sells pre-bent fuel line kits for 2WD 67-72 Chevy trucks. They don't appear to list anything for a K10 though. I just installed a set of their lines (supply and return) in my 2WD shortbed truck, and they fit well. The ends are flared for quick-disconnect fittings, so it requires the use of flexible line for the last foot or so at each end.
^^^What pj said.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#7 | |
Posted via Mobile Device Last edited by AllGoNoShow; 12-20-2021 at 10:37 PM. |
#8 | |
#9 | |
![]() Join Date: Jan 2021
