12-21-2021, 09:58 PM | #1 |
Boyds Welding Fuel Tank
I have this tank installed on my 66.
I am confused on the the 1/2 inch NPT vent. This is the rollover vent I think. The other port 5/8 inch is for a vacuum canister. I am installing a remote fill on the bed fender. See photo what i was planning. So should my remote fill have a port added then run a hose from that to the 1/2 inch brass fitting?? Regarding the 5/8 port; i dont plan on running a vacuum canister unless i have to; so just plug that port?? Posted via Mobile Device |
12-21-2021, 10:05 PM | #2 |
Re: Boyds Welding Fuel Tank
The brass fitting sticking up is a roll over valve, it can be used as a vent easily, in the event of a roll over, it closes and doesn’t let fuel out. The other port…? You may want to call the manufacturer and question them….
12-22-2021, 09:57 AM | #3 |
It's Better With Nitro
Typically, you want to vent the tank at the highest point, including the filler neck.
12-22-2021, 10:27 AM | #4 |
So would i connect the brass fitting on the tank to the small port on the filler neck that i have shown above?
12-22-2021, 10:38 AM | #5 |
That would work fine…
12-22-2021, 10:49 AM | #6 |
12-22-2021, 04:33 PM | #7 | |
If you do that wouldn't you just be recirculating the fumes instead of venting it. I think you need to plug both holes on the top of the tank and run the vent from the bung in the filler neck into the open air through a hose. Make sure the vent hose has a couple of loops in it which will keep the smell of gas from escaping. |
12-22-2021, 04:35 PM | #8 |
Don't you connect a vent hose from the filler neck to the tank?
65 stepside C20 |
12-22-2021, 04:41 PM | #9 | |
I know the brass port is a rollover vent but should go to something Second figure is from boyds website Regarding the vent line connection Thus why im confused Last edited by Afirehawk1; 12-22-2021 at 04:47 PM. Reason: Typo |
12-22-2021, 04:46 PM | #10 |
I am not seeing any links. never mind now I do. but it is too blurry to read.
12-22-2021, 04:49 PM | #11 |
The pictures look identical
65 stepside C20 |
12-22-2021, 04:49 PM | #12 |
Had trouble loading
12-22-2021, 04:52 PM | #13 |
Now I understand the confusion. I would call Boyds.
12-22-2021, 04:53 PM | #14 |
Other photo
12-22-2021, 04:57 PM | #15 |
I think the idea is when i fuel the tank remotely, as the fuel is placed into the tank, the vapors have to be pushed out and is circulated. i was going to use a vented fill cap as well
12-22-2021, 05:31 PM | #16 |
It might also be that if it is that low on the side there might be a tendency for the gas to slosh back up the filler neck and this would provide a place for it to go rather than out the cap which could ruin your paint.
01-05-2022, 01:16 PM | #17 |
on the rollover vent. there is mention of the old style vacuum carbon canister.
any suggestions or ideas on that? im using this filler cap instead. its a 1.5 inch filler pipe with an an overall of 2.5 inches. this fits perfectly on the top of the rear bed fender. Last edited by Afirehawk1; 01-05-2022 at 01:18 PM. Reason: typo |
