12-22-2021, 10:47 PM | #1 |
Chevy guy
What is this dohinkey?
Hi,
I've got a 70 C10 pretty much all original. It has the original 350 V8 and a TH350 trans. I'm doing a tune up and noticed a metal can in the vacuum line from the carb to the distributer vac can. It has another vac line and a wire going to it. I have no idea what the purpose of this is but it does look factory. I'm probably going to not use it and go a straight hose carb to dist. The reason I think it is factory is there is a prebent metal line from the carb to the box with hose connecter's. Thanks for any ideas. Jon
Tehachapi, Ca 57 BBW shortbed 64 C30 service bed 65 C10 long bed fleetside 70 C10 long bed fleetside 74 C30 flatbed |
12-22-2021, 10:56 PM | #2 |
Re: What is this dohinkey?
It’s a transmission vacuum switch.
Used to limit your vac advance until you’re in high gear. In a turbo 350 that would be in 3rd gear. An early pollution device. You can bypass it with a vac hose. |
12-22-2021, 11:50 PM | #3 |
Chevy guy
Thanks, I figured it was something like that.
I'll remove it and run a new line.
12-23-2021, 01:11 AM | #4 |
Don’t throw it away.
Some restorers look for them. They came on some chevelle, corvettes and Camaro’ s too. |
12-23-2021, 01:30 AM | #5 |
Chevy guy
No worries there, I'm one of those guys who save everything. Never know when a trade will get you something money won't.
