Old 12-28-2003, 06:22 PM   #1
moodyholler
moodyholler's Avatar
Help!! New Edelbrock and HEI
AM in the process of installing a hei and a 1406 Edelbrock. My hei is very close to the firewall. Will this be ok? Also on the 1406 I am having trouble w/ the kickdown and the throttle cable. They are not located in the right places now. I just ordered a bracket from Edelbrock (8103)? WIll it help? Thanks for anyhelp. Moodyholler
1998 WRANGLER I-6 auto
1972 LWB FLEETSIDE
1968 GMC SWB STEPSIDE
1994 C-1500 SWB 4.3 5 SPD
moodyholler is offline   Reply With Quote
Old 12-28-2003, 11:45 PM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
Your HEI will be very close to the firewall and it will be just fine.
I don't remember having to change anything on the carb though. Everything was there and I have installed 3 of these carbs on 70-72 trucks all with automatics.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 12-29-2003, 05:23 AM   #3
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
I got a adjustable bracket for the kickdown cable and gas. The edlebrock bracket should work.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 01-18-2004, 04:43 AM   #4
autolabor
Edelbrock and HEI
I have the same intake as you do and all i did was replace my old cable with a chrome universal bracket from Checker. It hooked up with a few modifications. I installed a new High Voltage billet Accel HEI. I ad to grind off a little from the top on the rear for clearance, but it does fit very close. I have the SM465 manual with the NP205 transfercase.
autolabor
1971 Chevrolet K-5 Blazer;
Yamaha Road Star warrior all stock.
autolabor is offline   Reply With Quote
Old 01-18-2004, 03:04 PM   #5
Blue Beard
Blue Beard's Avatar
I don't have the HEI yet but the carb wasn't a problem....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-06-2004, 02:07 AM   #6
Vlad
Vlad's Avatar
If you're uncomfortable with the closness of the hei to the firewall,you can do what I did. I simply took a ball-peen hammer and beat the firewall to a nice rounded shape to match the shape of dist. cap. quick and easy!!
Vlad is offline   Reply With Quote
Old 02-08-2004, 09:35 PM   #7
Heavy-Chevy
OUCH!!!!!!!!!!!!
The HEI will fit.Both of mine have them without any mods to th e wall.
TRUCKS & Autos that run:
1972 GMC Sierra Grande 3/4ton LWB 4x4
1972 Chevrollet K/5 with a 6"Lift, 462 heads "money pit"
1988 K3500 Crew "Big Red" 4x4
PARTS OR PROJECT TRUCKS:
PARTS for sale or trade:
WANT :
1972 parts blazer/Jimmy parts truck
1967-72 Parts Chevy/GMC Truck
NEED stainless hubcap for 3/4ton GMC
Heavy-Chevy is offline   Reply With Quote
Old 02-11-2004, 10:50 AM   #8
dvallot
Hei firewall distance
If you aren't going to go offroading, you need not beat the firewall. If you are, you need to bash it in. It will not be visible from the cab or the engine compartment. You will need a larger hammer than a small ball peen. Unless you have a big arm and plenty off swinging room. A nice sized bump or hole in the trail can knock the HEI cap off of the distributor and maybe crack it. Don't get stranded in the deep woods. **Deliverance
dvallot is offline   Reply With Quote
