Old 12-28-2003, 06:28 PM   #1
Gregsmx
Gregsmx's Avatar
Question tach wiring harness. where to connect?
I am upgrading my instrument cluster with a tach. The tach wiring harness has 3 cables:
Brown, which is a long cable and has a rubber firewall grommet on it indicating it goes into the engine compartment somewhere.
Reddish pink, which looks like it stays under dash.
Black. This is a ground wire.
Can someone tell me where to connect these 2 cables?
To make things more interesting, I am also installing a Painless wiring kit. Included with the under dash wire cluster is a pink wire labeled "Tachometer". So the question is which wire does it connect to, and where does the other go?
Thank you, Greg.
'75 Blazer RAT 4X4 "BLAZIN" - Custom frame off
Here's the website I'm uploading pics to: Greg's frame off project
Gregsmx is offline   Reply With Quote
Old 12-28-2003, 08:34 PM   #2
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
For the original harness, the pink wire plugs into the fuse box to an open "IGN" terminal and the brown wire hooks to the tach connection (marked "TACH") on your distributor cap.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 12-28-2003, 08:47 PM   #3
apstguy
LED King
apstguy's Avatar
It seems like it would be tough, but once you find the terminal markerd TACH on the distributor cap, you'll wonder why it was so easy.
Shouldn't there be a 4th wire for the gauge light?
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 12-28-2003, 09:13 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
This is funny! I just walked back in from doing the same thing on my 77. No, you don't need an extra lead for the lights. They are controlled by the dash lights...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-28-2003, 11:13 PM   #5
Gregsmx
Gregsmx's Avatar
These boards are fantastic. Thank you all for the information. Sometimes what seems so difficult can be fairly easy. And the project doesn't have to be scrapped afterall!
