12-25-2021, 02:51 PM | #1 |
low n' slo
Deleting e brake
Is this OK to do? I hate the handle on my 67 and my cables are frayed under the cab. also hate the steel cable coming through the firewall. is it OK to just delete the whole thing? truck will have an LS with 4l60E auto trans. also has air ride and it can not roll when aired out.
anyone else delete the whole setup?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
12-25-2021, 03:36 PM | #2 |
Re: Deleting e brake
Even though I have driven autos for 99% of my driving life (36 years) AND never got in the habit of setting the parking brake.... I have had to use it a few time for during brake failures. I cannot recommend deleting the system, but rather fix it and keep it working in good order.
The park/emergency brake system is not that good to use as a way to get home after the master cylinder goes out, the line breaks, or otherwise....but, I guarantee that regret will be the first thing to go through your mind in a brake failure.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
12-25-2021, 04:03 PM | #3 | |
Personally It wouldn’t bother me. If I was worried about brake failure I wouldn’t drive the truck |
12-25-2021, 04:29 PM | #4 |
Nope, it’s not ok in most states (and zero that I’ve ever lived in, and have moved around quite a bit). And it’s really not a good idea either, even if you think you won’t need it, you eventually will (or should) use it. Cannot roll when aired out is probably not a viable workaround when in a scenario where you actually need a pbrake - yes, there are times you should use one even with an automatic.
12-25-2021, 05:09 PM | #5 |
low n' slo
tbh I have been driving for 20 years and not once have I ever had to use my e brake. nothing but flat lands where I'm from but I see you guys point. I will look into it more in detail and see what needs to be replaced to get it working right
12-25-2021, 07:09 PM | #6 |
Maybe get an electric parking brake. They aren’t that bad to Install either. The only thing I don’t like is they are all or nothing.
12-25-2021, 10:31 PM | #7 |
The only time I use my e-brake is when I'm working on my other vehicles. For my '67 I removed it as I would have had to rebuild the whole system. I will be upgrading my master cylinder from a single line system to a dual, just to be sure I have some brakes. As for when I work on it I will just chalk the wheels so it don't roll.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
12-25-2021, 11:18 PM | #8 |
Rock auto for all 4 cables AC Delco gold is only about $60.00 , Really not something to delete when the name starts with "Emergency" brake
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
12-26-2021, 11:25 AM | #9 |
kev2809, Sent you a private message
12-26-2021, 11:40 AM | #10 |
That is one of the features I like on the 67 & 68.
It reminds me of older trucks that had hand brake lever in the center. I vote fix it. If it's the big handle you don't like? I don't know how hard it would be to convert it to 69-72 style?
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
12-26-2021, 01:19 PM | #11 |
It's an old guy thing , The 67-68 hand brake and manual trans worked great if you had a load or pulling a trailer up hill and had to stop halfway for a traffic light or stop sign , You just reached down and pulled up on the hand brake rather than ride the clutch waiting on traffic to clear made it a whole lot easier to get going again and saved your clutch , You can't do that with a floor E brake .
12-26-2021, 01:23 PM | #12 | |
12-26-2021, 01:45 PM | #13 |
low n' slo
Well. I'm thinking of just wrapping the actual cable by the firewall in a wireloom or something and repairing whats missing. The actual handle under the column doesn't bother me all that much but i figured if there was a chance to remove it all together than why not.
12-26-2021, 02:13 PM | #14 | |
12-26-2021, 02:16 PM | #15 | |
12-26-2021, 02:41 PM | #16 |
I actually really like the hand style. I had a manual truck before that it was VERY handy when towing, heck even stop/go/parallel parking etc on an incline. I used it all the time. It got me out of some sticky situations. I really don't like the pedal E brake with a manual not sure why they moved it. The pedal style really limits it as a tool.
Anyways, its most likely illegal where you live and if you did cause an accident you better hope the other party doesn't find out. That's prime lawsuit material! Personally I would not drive something that didn't have an e brake.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
12-26-2021, 03:56 PM | #17 |
16401849429525845957225115628482 by [url=https://www.flickr.com/photos/97391199@N06
I wouldn't delete it, but you could convert it to something more functional
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
12-26-2021, 04:06 PM | #18 |
The one time I really needed an ebrake was in a 67 GMC, and that handle probably saved someone's life. I am not sure I would have found it if it was on the floor, either.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
12-26-2021, 06:08 PM | #19 |
BlahBlahBlah
I had the brakes go out in my 72 Burb in evening rush hour traffic and I had around a 40 mile commute left.
I used the foot ebrake and the ebrake release handle to get home. Well most of the way until the black handle popped off. Luckily, I was still able to hold on to the piece the handle is stuck to, good grip =) Its the opposite of flat here out in the west side of the Cascades, an ebrake is essential.
12-26-2021, 06:15 PM | #20 |
don't have an E brake on my 68. It was missing when I bought the truck, never thought about looking for one. maybe I should
12-26-2021, 10:35 PM | #21 |
What is all this talk about e brakes? My truck doesn't have one. It does, however, have a park brake.
12-26-2021, 10:46 PM | #22 |
Well, it is a parking brake that is mighty useful as emergency brake. I like maintaining my truck in 100% operating condition and passing inspection every year, and driving it all over the state.
12-26-2021, 11:37 PM | #23 |
[quote=jaros44sr;9011341]16401849429525845957225115628482 by [url=https://www.flickr.com/photos/97391199@N06
I wouldn't delete it, but you could convert it to something more functional[/quote] Jaros44sr -- Is that a dual Left/Right bootlegger hand brake system?
12-27-2021, 02:51 AM | #24 |
I don't think the self adjusters will work properly with no e brake.
I know I have seen it on other vehicles, not 100% if these are the same. |
12-27-2021, 07:50 AM | #25 |
The customs and CST's have a cover for the handle. It dresses it up a bit. Should be an easy thing to pic up and fit to your truck.
I've had my truck for 20+ years and never touched the e-brake. I have too many unpleasant memories of my mom driving away forgetting to release the e-brake with a cloud of smoke rising from the back of whatever she was driving! On a side note, I'm afraid that if I set mine after 25+- years of having never been used, it won't release. Is this a consideration? My brakes are in otherwise good condition.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
