Airbags for towing
Lowered my 71 C-20 a few years ago, took out the overload leafs, and had the stock springs re-arched. Now I have this wild idea that I want to tow my drag car and enclosed trailer with the 71. But.. I need airbags to pick the ass end up when I put 10k lbs on it. Anybody know of a kit or am I piecing it together myself? Truck has a Dana 60 in the rear.
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '24 GMC CC 4x4 Duramax Dually |
Re: Airbags for towing
Do a search for Firestone air bag kits.
Lots of kits out there. Here’s one of many. https://www.summitracing.com/parts/fip-2404 |
It looks like most kits are for coil over applications.
I might buy this setup and see if I can make it work https://www.sdtrucksprings.com/index...SABEgKrTvD_BwE
Ridetech & Airlift both offer an Air-over-Leaf set-up for assisting a leaf spring set-up. There are 'under' frame set-ups as well as 'side' frame set-ups.
All about them K’s
![]() Join Date: Jun 2014
I’ve got air lifts under my DD 2018 Sierra HD. This truck has had them since new; now at 115,000. I run them at about 65lbs constantly (service bed) and they have held up great. No real issues at all. Get the 2-300 dollar compressor kit, I’ve run them with just the schrader valves in the past, that setup will work but is very much not ideal.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
