12-26-2021, 03:33 AM | #1 |
Attaching plastic grille to the surround
I finally got around to attaching plastic grille to the surround and ran into some issues. The rectangular holes, for the retaining inserts, are not the same width. Some are so tight the nylon insert will not go through the hole and others so loose they fall through even with the screw installed.
The top slots were. .255-.252-.268-.313 Bottom slots are .330-.320-.320-.330 The nylon inserts are all the same at .310 I plan on using a file to widen the narrow slots. Unsure what my plan is for the loose ones. I am able to work out the inserts by hand with the retaining bolt installed into the insert. I will have to figure out something to keep them from rattling. Just a testament to the great job GM did on the trucks originally. Wonder what a complete aftermarket truck would look like if the parts were left as delivered. |
12-27-2021, 10:45 PM | #2 |
Re: Attaching plastic grille to the surround
You might try going to your local parts store and get a variety pack of the plastic retainers. You should be able to find one in the pack that would work.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
