Old 12-26-2021, 11:25 AM   #1
twoskies
twoskies's Avatar
Removing Bed
Good Morning All
im going to be removing my bed, 1966 short stepside
all the wood is rotten or gone
assuming it helps support
Can i just 4 strap it on the corners and lift with my engine lift
(worked ok on my 1972 long fleetside)
Or do i need to weld braces to keep from caving in on itself
Thank's
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 12-26-2021, 11:49 AM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Removing Bed
If the header panel is still bolted in and tailgate still attached, you will probably be ok. If you leave the cross sills, that are underneath the wood, bolted to the bedsides, you'll have plenty of strength to keep it from caving in
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 12-26-2021, 12:06 PM   #3
jayoldschool
Moderator
Re: Removing Bed
You'll be fine, but it's easier to just strap around the cross members under the wood and use the engine hoist. Easy to balance it.
jayoldschool is offline   Reply With Quote
Old 12-26-2021, 01:05 PM   #4
SkinnyG
SkinnyG's Avatar
Re: Removing Bed
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 12-27-2021, 02:12 AM   #5
62bagger
62bagger's Avatar
Re: Removing Bed
Originally Posted by SkinnyG View Post
That looks alot like how I got my bed removed.
62bagger is offline   Reply With Quote
Old 12-27-2021, 11:37 PM   #6
seabeevin
seabeevin's Avatar
Re: Removing Bed
I just sling em up and use my tractor loader with forks. Boom-off the truck.
Reckon I'm spoiled.
65 stepside C20
seabeevin is offline   Reply With Quote
Old 01-08-2022, 08:53 PM   #7
Angrywood
Re: Removing Bed
I literally just bolted the bed back onto my 62 today. When i took it off i was able to move the bed around with the rotted wood by myself. Not saying i am he-man or anything but was able to with the long bed.
After i put the new wood in, that was a different story. It was significantly heavier. I used an engine hoist and used the cross sills as my lift points. Long story short, I believe you will be fine lifting from the cross sills if i was able to with new oak when putting it back on.
Useful tip…. Take your wheels off and drop that sucker down as low as you can. Don’t have to lift it as high to get over the wheels.
I attached a picture if it comes through on how i strapped it.
Angrywood is offline   Reply With Quote
Old 01-09-2022, 03:52 PM   #8
bigmoe
bigmoe's Avatar
Re: Removing Bed
I don't have an engine hoist and do everything with a fixed ceiling hoist. I used straps in the four stake pockets, raised it, and rolled the truck out. When I reinstalled it the box was painted and stake pockets were smoothed. I made a wooden frame that went under the box sides at the tops with 4 x 4's going across. No tailgate on but new bed wood was installed.
bigmoe is offline   Reply With Quote
Old 01-28-2022, 02:44 PM   #9
racecougar
racecougar's Avatar
Re: Removing Bed
Here's my method using an engine hoist and a little lumber: https://www.youtube.com/watch?v=LmmyRs8tSU0
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
