12-27-2021, 12:35 PM | #1 |
Will '84 power window regulator work is '67 door
I was looking at converting my '67 to power windows since my manual regulators are seized up. I was looking at various power window setups and came across the '84 power window regulators which APPEAR to be the same as my '67 regulators. Are they indeed the same? Or would I have to do some modifications to make them work?
Also, I have been looking at Autoloc Power Accessories 9848 on Amazon. It's generic setup and would require some fab work. If anyone has experience with them please let me know your thoughts on them. Thanks
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" Last edited by Peanut74; 12-27-2021 at 12:37 PM. Reason: clarification |
12-27-2021, 02:37 PM | #2 |
Re: Will '84 power window regulator work is '67 door
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-27-2021, 03:43 PM | #3 | |
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
12-27-2021, 09:59 PM | #4 |
Yes, I am aware of that thread and that is one option. But if the '84 bolt right in that would be the easiest option. It would also save me time which is worth something.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
12-28-2021, 12:02 AM | #5 |
I'm curious to see how it works out.
12-28-2021, 09:53 PM | #6 |
i once had a square body door apart a long time ago and looking at my current door i was thinking the same thing i couldnt remember the year . im in to see where this goes
01-01-2022, 08:20 PM | #7 |
Well I looked the local pullapart yard and no pickups that year were there. So decided to do power windows this way
http://67-72chevytrucks.com/vboard/s...d.php?t=601167 In searching through my parts I found a couple of Toyota power window regulators that I can use. I checked the motor teeth profile to the C10 regulator gear and they match. So that will take care of the power portion. For the switch I plan on using parts from the window crank mechanism to activate it. This should be interesting to see if I can get to all work.
