12-28-2021, 01:26 AM | #1 |
Ignition Bezel?
What Is The Purpose Of The 3 Notches On The Ignition Switch Hole?
What Prevents The Switch From Spinning? Thanks Posted via Mobile Device |
12-28-2021, 01:37 AM | #2 |
Re: Ignition Bezel?
the notches match the tool that is used to install/remove the bezel - the tool is what you use to tighten or loosen it.
12-28-2021, 02:43 AM | #3 |
Thank You
Do I Need To Install The Key Tumbler First Or After? Does It Just Push In? Posted via Mobile Device |
12-28-2021, 03:30 AM | #4 |
Re: Ignition Bezel?
Afterwards.
12-28-2021, 12:24 PM | #5 | |
The Older Generation
Re: Ignition Bezel?
Install the switch first. Make sure that the orientation is correct. To install the tumbler you will need to have the key in it. Insert the tumbler with the small hole at the top. Turn clockwise (to the right) to lock the tumbler into place. LockDoc
